10-28-2023, 09:29 AM | #1 |
Drives: 2013 Chevrolet Camaro RS/2LT Join Date: Jun 2022
trickle charger
Does anybody use a trickle charger over the winter months with the battery still in the car? Can you hookup under the hood or does it need to connected directly to the battery in the trunk? I'm reasonably sure most responses will be directly to the battery but is there a convenient place to run a line out then?
I have been down a few rabbit holes searching through the threads but they are typically old and end up arguing about what type of battery to put in the car, why is it in the trunk, etc. Any tips are appreciated. |
10-28-2023, 09:49 AM | #2 | |
Drives: 2015 zl1 m6 Join Date: Jan 2020
I use a Noco battery tender . Hook it up to the positive connection under the hood and the negative ground pin by the air intake . I route the cord up thru engine bay from underneath the car .driver side front corner there’s some opening to snake the cord thru
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.7 @133.9 |
10-28-2023, 10:22 AM | #3 |
Older Than Dirt
Drives: 2010 & 2013 Camaros Join Date: Apr 2010
I use an old-school square Battery Tender Jr. on each of the Camaros while they sleep. Keeps the original ACDelco unit and the Die Hard AGM topped off on both. Just clip them on under the hood and no issues. Red light charging, green light float.
They're cheap enough and do the job and has been for years. I won't get the box unit they make anymore because every one of them has died prematurely. The Jrs. are definitely more robust. NOCO Genius has something very similar in about the same price range, and it looks very promising too. Just haven't had the need to buy one since the Jrs. are still going. I also have a CTEK automatic trickle charger that works pretty awesome too for a car I have out in the shop. But it was much pricier.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
10-28-2023, 10:31 AM | #4 | |
Yep, I had a ctek aswell but after about 4yrs it finally failed . It was failing to register when the battery was full and to kick on to maintenance mode . Would have bought another ctek just didn’t want to wait for it to be shipped to me . Noco genius seems to doing the trick so far Agree- the cost is pricier
PB:10.7 @133.9 |
10-28-2023, 10:36 AM | #5 |
For when I do let mine sit, which has more so recently, I have the CTEK Model 7002 Multi US and it works great, so far.. Can be used on flooded LA batteries, AGM's and gel's..
10-28-2023, 11:19 AM | #6 |
Older Than Dirt
Most all of them do a myriad of battery types nowadays. But yeah, I've got the 7002 CTEK out in the shop and I love it. Just that if/when the Jrs. give up the ghost, only then I might spring for more CTEKs.
10-28-2023, 11:27 AM | #7 |
Awesome..
10-28-2023, 12:08 PM | #8 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Tender Jr. here. Been running that for the past 8/9 years on my cars and motorcycles. I have mine directly on the battery. I back my cars in the garage, and there's a plug right by the trunk.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
10-28-2023, 01:59 PM | #9 |
It don’t come easy.
Battery Doc here. No complaints. Use it year round.
10-28-2023, 02:43 PM | #10 |
Drives: ABM #93 Join Date: Oct 2018
I’ve got one on mine don’t remember the brand off hand but since my car only seen >1000 miles per year it stays on it pretty much all the time. It’s wired direct to the battery and I just route the cord out gently under the truck lid. Never had a problem. Original battery is almost 15 years old and still fires up perfect everytime, even when off the tender, sitting for a few weeks.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
10-28-2023, 04:43 PM | #11 | |
I use and do the same. Sent from my iPhone using Tapatalk
'22 2SS | Wild Cherry Tintcoat | Design Package 3 | NPP | MRC | A10 | NAV | Ceramic Coating | Full Frontal PPF | New Hood and Side Stripes | Michelin PS AS 4
Range AFM Disabler | Mishimoto Catch Can | Diode Dynamics side markers | Cold Air Inductions CAI | LLoyd Velourtex front/trunk mats with Camaro SS logo ZL1addons Deluxe Rock Guards, Stealth Lift Pads, and Tow Hook | Escort MAXcam360c | Footwell Lighting | Banks gauges in ZZPerformance pillar pod | Paddle shifter extensions |
10-28-2023, 06:13 PM | #12 |
Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
Battery Tender Jr for me. serves me well.
10-28-2023, 07:23 PM | #13 |
Thanks for all the input. I use the juniors on the HDs and the Polaris. Was figuring on getting another one. Hooking it up under the hood does seem the most convenient but was worried about it messing with the fuse box there. Had just let it sit previously but had to replace the OEM battery this Spring. Noticed the auto window feature started acting funny. Glad the car was kind enough to give me a warning! The NOCO genius looks like it could be a contender for the job as well. Again thanks all!
10-28-2023, 07:36 PM | #14 | |
