Old 11-03-2023, 05:32 AM   #1
docwra
Drives: 2015 Z28
Anyone know where I can get a new LS7 block?
Long story short, took my Z28 on some European trackdays last year.
At roughly 170 mph on the autobahn one of the sportcats collapsed, leading to head gasket failure and a piston cracking.
Got that fixed but car overheated again shortly afterwards, have rechecked and theres a crack in one of the bore liners
Looking at getting it resleeved but if this isnt possible Ill need to replace the block, funnily enough they arent exactly common here in the UK
docwra is offline   Reply With Quote
Old 11-04-2023, 06:41 PM   #2
AustexaSS
Build Date - Dec 08, 2014
AustexaSS's Avatar
Drives: 2015 Z/28, #1007, Black A/C Stereo
I would suggest contacting any of these reputable companies. They all specialize in LS engines. You may need to be prepared to take the LS block of your choice and modify it to be an LS7.
https://sdparts.com
https://www.texas-speed.com/
https://www.mastmotorsports.com/
https://americanheritageperformance.com/
AustexaSS is offline   Reply With Quote
Old 11-04-2023, 08:05 PM   #3
1970judge
Drives: 2015 Z/28, 2007 HHR
https://sdparts.com
I second this. If I were in you’re position SDPC would be my first call. And the others listed.
1970judge is offline   Reply With Quote
Old 11-05-2023, 04:58 AM   #4
docwra
Drives: 2015 Z28
Nice one, thanks guys. I really want to stick with the LS7 if I can as its not really an Z28 without one, hopefully sleeving will work but it snot going to be cheap either way
Old 11-05-2023, 05:14 AM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
You live in UK,these are possible in FI.
https://www.kivinummiracing.fi/index...torit/ls7-7-0l
https://laukkanenmotorsport.fi/c1086...es-bare-blocks
Old 11-23-2023, 04:48 AM   #6
fatima mehru
Drives: Honda Civic Oriel
Replacing the LS7 block is a viable option if resleeving is not possible. The LS7 block is not commonly found in the UK, but there are a few sources that can provide you with a new one. Some reputable sellers include Katech, Mast Motorsports, and Ed Rinke Performance.
fatima mehru is offline   Reply With Quote
Old 11-23-2023, 05:37 AM   #7
docwra
Drives: 2015 Z28
Cheers, its at the machinist being resleeved atm, fingers crossed it will work!
Old 11-24-2023, 06:35 PM   #8
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
I bought a cracked LS7 block off of a racer friend of mine. Was cracked from a valve snapping off. The crack went into the water jacket. His local machine shop wouldn't touch it. I paid him $200 for it. I took it to my world class machine shop Jan-Cen Racing Engines and Mike Janis himself came out to take a look at it. He said that he's repaired way worse blocks and that it shouldn't be a problem. I will let you know when I get it back, what the total dollar amount was.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 11-26-2023, 08:11 PM   #9
Dega Man
Drives: ZL1
Another great shop is Livernois, they have a very nice machine and fabrication facility which can more than likely easily handle your issue. If that fails I would highly recommend going with a RHS block which will handle whatever you throw at it especially in a natural aspirated setup.
Dega Man is offline   Reply With Quote
Old 11-27-2023, 04:30 PM   #10
Trickskier
Native Floridian
Trickskier's Avatar
If re-sleeving doesn't work you can buy an LS7 block directly from Chevrolet Performance. Link below:
https://www.chevrolet.com/performanc...ylinder-blocks
Old 11-27-2023, 04:37 PM   #11
FASTFATBOY
Drives: 2013 ZL1
Well THAT sucks
2015 1SS 1LE, Magnuson 2300 Heartbeat and headers. 550rwhp STD, 535 SAE.
FASTFATBOY is offline   Reply With Quote
Old 11-28-2023, 08:57 AM   #12
docwra
Drives: 2015 Z28
Originally Posted by FASTFATBOY View Post
Well THAT sucks
Tell me about it, Id just spent the best part of $5K getting the head gasket - that we thought was the problem - fixed as well
If the liners dont work I dont want to think about the potential cost, I cant imagine getting a block shipped from US to UK is cheap and if I put anything other than an LS7 in its not a Z28 anymore ........
Old 11-28-2023, 11:00 AM   #13
Dega Man
Drives: ZL1
Excuse my earlier post, I overlooked that you were located in the UK, however there are Chevrolet dealerships in the UK I think that you should be able to order the block that trickskier provided if it comes to that.
