Old 11-07-2023, 09:11 AM   #1
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Red face It got a little scary last night
Every time I'm working on the car I got my system playing Music (Rammstein)
I Always use the NOCO GENIUS5, 5A Smart Car Battery Charger to trickle charge it. So I have a 300 amp AM Alternator, going into the Yellow Top AGM Battery I also got a second battery XS 750 Series AGM mounted where the stock Amp used to be, both batteries are on a 250 AMP Dual Battery Smart Isolator which I believe went bad or something, you only turn it on when the main is drained so you still be able to crank your car and you have to immediately turn it back off after.
Well long story (Sorry) short my secondary was about to blow, big bulge, I got a new one coming but I think I will just connected in Series instead of the Isolator. Of course I disconnected it immediately and moved it away, That's the reason I got a FE in my Car lol
Anyone got an Idea what has happen here?
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 11-07-2023, 11:56 AM   #2
Caveman_SS
Will Cave
Caveman_SS's Avatar
Drives: 2010 Victory Red 2SS LS3
Man, that's pretty sketchy Glad you caught it in time before it got worse.
Caveman_SS is offline   Reply With Quote
Old 11-07-2023, 12:08 PM   #3
Dega Man
Drives: ZL1
If you connected in series, you doubled the voltage to 24 Volts DC which is not good the electronics which is good for no more than 16 volts DC. When running two 12 Volt batteries in your car that's a 12 volt system, you should connect them in parallel (positive to positive and negative to negative to negative) this will give you increased current and capacity potential but still be 12 volts.
Dega Man is offline   Reply With Quote
Old 11-07-2023, 03:39 PM   #4
Infidel67
Life's just a Ride
Infidel67's Avatar
You got that right lol
Old 11-07-2023, 03:43 PM   #5
Infidel67
Life's just a Ride
Infidel67's Avatar
They are not in in series, and I don't like Cap's
Old 11-08-2023, 04:03 PM   #6
Dega Man
Drives: ZL1
My mistake, I interpreted your last sentence in the original post the wrong way, it stated you made a connection in series, I took it you were speaking of the battery, sorry.
Old 11-08-2023, 09:51 PM   #7
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Have you taken the XS battery out of the box, is there a crack in it ?
Old 11-09-2023, 02:10 AM   #8
NZZL1
NZZL1's Avatar
Drives: 2013 BRM ZL1 Camaro M6
Please confirm that you are not charging both batteries in parallel. If you are, this will be the cause of the failed battery.
NZZL1 is offline   Reply With Quote
Old 11-09-2023, 03:08 AM   #9
Infidel67
Life's just a Ride
Infidel67's Avatar
Yes, no crack and still holding charge
Old 11-09-2023, 03:10 AM   #10
Infidel67
Life's just a Ride
Infidel67's Avatar
No problem Dega
Old 11-09-2023, 03:10 AM   #11
Infidel67
Life's just a Ride
Infidel67's Avatar
Look at the Pic and you can see it
Old 11-09-2023, 04:36 AM   #12
chevy pilot
How old XS battery ?
Old 11-09-2023, 10:20 AM   #13
Infidel67
Life's just a Ride
Infidel67's Avatar
A year old, like I said I think the Isolator made a boo boo
Old 11-09-2023, 10:31 AM   #14
gtstorey
I'm struggling to come up with a scenario how wiring either on parallel or series would damage the battery. In series you get 24 volts but that will hurt everything other that the battery and would not keep the batteries charged. In parallel and nothing bad happens, just like using jumper cables or how many diesels 12v trucks are wired.
It looks like an internal battery problem to me.
