Old 11-10-2023, 01:36 AM   #1
darcycook
darcycook's Avatar
Drives: 2013 v6 auto 1LT
Front strut stem broke
I needed input I have a2013 LT With a 2in. Lift on struts. I was backing up very slow turning the steering wheel clock wise almost much to max and heard a snap it was the front left strut the stem snapped about 2in. Down from top. Very weird. Any thinking ��
darcycook is offline   Reply With Quote
Old 11-10-2023, 09:06 AM   #2
gtstorey
2" lift? Probably not going to be much feedback, since not very common to lift a Camaro.
Old 11-10-2023, 10:05 AM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
I was thinking the same thing.. Whaattt ??? Lifted?? There's your first problem..
Old 11-10-2023, 07:03 PM   #4
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Not much help from me, cause we're more like "How low can you Go"
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 11-10-2023, 07:18 PM   #5
darcycook
darcycook's Avatar
like strut stem broke , i think it was the backing up with a turned wheel?
Old 11-10-2023, 07:20 PM   #6
darcycook
darcycook's Avatar
as for the lift i am 67 old school
Old 11-12-2023, 12:55 AM   #7
PaulsSS
Drives: 15SS Camaro
I think I know what happened, you lifted it and either removed or modified the upper strut mounts. They have about a inch or so play designed in so when the wheels are turned hard and the steering geometry gets extreme the top of the struts can move so they don't break off. LOL If you had looked closely when the car was stock turning the wheels to lock you would have seen as you get close to lock the upper mounts give and take stress off the struts. I suggest to go back to stock and first understand how the steering reacts to lock inputs before something worse while traveling forward occurs.
PaulsSS is offline   Reply With Quote
Old 11-12-2023, 03:07 PM   #8
darcycook
darcycook's Avatar
O my yes. Makes sense. I didn’t know how it worked. I bought a 2in. Spacer that screws on the top of strut. From universalcatlifts.com I was extremely lucky I was close to my home or I could have it towed about 2 miles to do the repair
Old 11-12-2023, 03:36 PM   #9
darcycook
darcycook's Avatar
I don’t know how to post an image from my iPhone picture library
Old 11-12-2023, 07:02 PM   #10
bsn
Drives: 2013 ZL1
Your only a few years older than me, we used to keep the front end stock and raised the rear. Back in the early 80's we got smart and lowered the rear and loosened the front so we could actually get traction.
bsn is offline   Reply With Quote
Old 11-13-2023, 01:39 PM   #11
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, I'm 66. And back in the "old school" days we used to run 50/50 shocks in the rear so it would "squat" and go, ran 90/10 race shocks in the front to as bsn said, "loosen" it up so it would raise up and transfer the weight to the rear.
Old 11-13-2023, 07:10 PM   #12
darcycook
darcycook's Avatar
Well my goal was cosmetics but I realize now that the way the lift at the top if you’re going to be safe. The left neeeded to be at the bottom. And they make those.
