![]() ![]() ![]() ![]() ![]() Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
P069E/P080C
After limping home after my SC belt snapped, these 2 codes popped up. Can't put my car in reverse unless I jam it in its slot. Car will start, then die right away. I've read some threads stating it could be a fuse or wire. Any additional help would be great.
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
P069E is a request from the fuel pump module to turn on the mil. You will have to have a scanner that can read that module.
P080C is low voltage to the skip shift solenoid. It looks like fuse 14U (7.5amp) feeds both Fuel pump module and skip shift solenoid. But it also feeds a lot of other stuff also so I would expect even more codes if it is that fuse. Make sure you inspect the harness real well. |
There were actually multiple codes that's popped up. When I pulled over the side of the road, the plug that connects to the maf was removed. As soon as my belt snapped, service stabilitrac also came on. That's when I pulled over and removed the belt carnage.
Other codes that popped up, which I cleared. P0102- maf error P0141- o2 sensor error P0113- Intake Air Temperature Sensor 1 Circuit
Not sure how the o2 figures in, but the rest makes sense. The maf/intake temperature are fed from that fuse so it probably shorted when it was damaged.
I had to drive 20 min with the SC not pushing air. If it is the fuse, will the cell autocorrect itself, especially with the fuel module? Would I need the tech 2 obd2 scanner, or any scanner would work to clear the cel?
#6 |
Probably can just disconnect the battery and clear the codes. If not, it doesn't have to be the tech2, but it will take a somewhat higher end scanner to talk to the Fuel pump module.
#7 |
![]() Drives: 2011 2SS, 2006 GMC Sierra Join Date: Jul 2019
Tech 2 does not support F bodies
#8 |
7.5 fuse was popped. Just waiting on my replacement belt to start it. Hopefully that's it.
Ty G
#9 | |
#10 |
#11 |
I frickin hope so. This car has been a gift and a curse. lol I have to replace the mad plug/clip. You guys know the p/n
#12 |
Spoke to soon. Car did start with the fuse, but car won't go into reverse. Also showing P2534... could just be the car has been sitting for 4 days on a tender.
Progress in the right direction.
#13 |
After praying to the car gods, and bashing my hands on the steering wheel, everything checked out. No codes/reverse works..... just need the belt to come in.
#14 |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Good luck & I hope you are all set!!!
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
