Old 11-14-2023, 10:21 PM   #1
Alfdawg
Drives: 2014 camaro ss
Help! Is this the right part number and price
It's time for me to replace my pads and rotors. I decided to stick with oem parts. Everything was good until I looked up the rear oem rotors. Is the part number for the oem rotors (92245929)? And if so the price is between $220 and $260 for one. Is this correct? If that is the price I will be getting the factory pads all around and aftermarket rotors. Will the factory pads work well with aftermarket rotors? I was thinking ebc, Baer, or Power Stop.
Alfdawg is offline   Reply With Quote
Old 11-14-2023, 10:39 PM   #2
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Check rock auto for that info might even find cheaper.
Orange Krush II
