11-14-2023, 09:41 PM | #1 |
Drives: 2014 camaro ss Join Date: Oct 2018
Help! Is this the right part number and price
It's time for me to replace my pads and rotors. I decided to stick with oem parts. Everything was good until I looked up the rear oem rotors. Is the part number for the oem rotors (92245929)? And if so the price is between $220 and $260 for one. Is this correct? If that is the price I will be getting the factory pads all around and aftermarket rotors. Will the factory pads work well with aftermarket rotors? I was thinking ebc, Baer, or Power Stop.
11-15-2023, 03:14 AM | #2 |
Drives: 2014 2LS RRM Join Date: Feb 2015
Check Rock Auto. Looks like AC Delco rotor should be around $83.
11-15-2023, 12:24 PM | #3 |
I found the rear rotors on Amazon for a little over $100. I'm skeptical because every else has them for around $220
11-15-2023, 12:53 PM | #4 |
Drives: 2010 Camaro 2ss/rs, 2008 Avalanche Join Date: Jan 2019
Like mentioned above, Rock auto has very good prices!
2010 Rally Yellow 2ss/rs , M6 ,416ci , K1 rods & crank,weisco -3.0cc dome pistons,.040 head gasket, 11.5 compression,1 3/4" LT ,3" pipes w/x-pipe no cats, Cam Motion cam 239/247 113+3 .621"/604" lift , BTR .660 Platinum dual springs w/Titanium retainers, CAI . Stock ls3 heads,intake,injectors & TB. 515rwhp/500rwtq.
11-15-2023, 12:58 PM | #5 |
I went on rock auto and the oem rear rotors are $193 a piece
11-15-2023, 01:40 PM | #6 |
Drives: 2010 Camaro 2SS L99 Join Date: Apr 2023
Look at the ACdelco ones, they are the company that produces parts for GM that GM doesn't have the capacity to produce anymore (simplified explanation), it's the same exact part in every way to OEM, I am seeing about $56 per rear rotor on rock auto
Behind every scratch is a story on what not to do, and my car has a lot of stories.
11-15-2023, 04:31 PM | #7 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
I would consider the Brembo or the ACDelco Performance ones on RA if I was ordering.
