![]() Drives: Camaro ss 2010 / Caprice 2013 Join Date: Jul 2023
2010 LS3 Burns oil
Hey guys I have a 2010 SS 148KM she’s burning oil but has no leaks at all I filled it with the 5W40 shell to the top dot and today it was on the last dot two weeks ago I guess.
Noticed some oil on the intake elbow of the PCV hose and it's kept falling off a bit. so any thoughts before rebuilding? |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I would run a compression test before I jumped into rebuilding.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
Give speed a chance
Drives: 2015 Camaro 2LS, 2015 Camaro Z/28 Join Date: Nov 2019
+1. Troubleshoot first. Then spend money. Which Shell oil are you running? I hope it's not Rotella. You should be running a good quality Dexos 5w30 unless you've been instructed differently by a knowledgeable builder.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: ABM #93 Join Date: Oct 2018
Good advice above!!! You might try changing oil brands around but keeping the recommended weight, I’ve seen some engines not like a particular brand but be fine with another brand.
Also I would Check the PCV system over real good before you get to wrapped up in a rebuild. if it’s building too much pressure it can cause it to burn oil. Also if the valve guides or seals are worn it will cause it to use oil but not really need a rebuild. Is that 148,000 MILES or 148,000 KM? Just to make sure we are on the same page. I would both, check compression and do a leak down test to help diagnose things further if the PCV system checks out.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter. ‘87 IROC-Z Iroc blue. all original unmolested with 50K miles. |
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
Another thing you can do is pull the plugs & post some pics. An easy way to keep them in order is to poke 8 holes in a cardboard box & mark them 1,3,5,7 drivers side & 2,4,6,8 passenger side.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
#6 |
Thanks y’all for the advice, sorry to respond late I’m new to this website.
148.000KM using shell helix ultra L, mods Xforce cutback and catalytic converter delete with tune, after tuning it begin to burn oil. After a hard pull tonight when i reached maybe 5600 rpm i got the "Service Stabilitrak" light go on and of immediately, so i plugged my OBDscanner and i got p0300, p2272, p0443 |
| Tags |
| burning oil, ls3 5thgen, oil change, oil leak, rings |
