11-18-2023, 03:35 PM | #1 |
Drives: Camaro ZL1 Join Date: Jul 2022
ZL1 A10 Burnout Issue
I'm trying to do a burnout at the track. I'll push traction control twice and go into race mode, but the car will rev out to 3k and bounce between 3k and 2k and backfire a lot. I don't know if I'm not turning of TC correctly or maybe if the previous owner had something installed cause it almost sounds like it's two stepping. Is this normal? My tires won't even spin.
11-18-2023, 03:48 PM | #2 |
Drives: 2SS 1LE Join Date: Oct 2011
Hold the TC button till both of the lights come on.
Everything happens for a reason, except when it doesn't, but even then, you can, in hindsight, fabricate a reason that satisfies your belief system.
2018 2SS 1LE 2023 Colorado ZR2 2022 Stinger GT-line AWD |
11-18-2023, 04:15 PM | #3 | |
Drives: 24 ZL1, 6.2L Denali, 73 SplitBumper Join Date: Jun 2023
2024 ZL1 Radiant Red / Coupe / M6 / PDR / BCD / Carbon Scoop, Dash, Shifter / Red Seat Belts / Black Lugs
https://cws.gm.com/vs-cws/vehshop/v2...FJ1R60R0111531 |
11-18-2023, 06:17 PM | #4 |
Drives: '20 ZLE Join Date: Jun 2020
Hold down the off button by the shifter until TC off shows on gauge panel. Burnout in manual. Start tires spinning in 1st and shift to 2nd before taking it up to 5-6k
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
11-18-2023, 06:19 PM | #5 |
Drives: 2019 zl1 6 speed Join Date: Jul 2017
I had the same issue, I believe it's because you are in race mode and it has its own traction mode maybe? When I reviewed my pdr, traction control was popping up after I put it in race mode. Maybe try regular mode and hold the traction button to turn off.
11-18-2023, 08:49 PM | #6 |
Drives: 2018 Camaro ZL1 Join Date: Aug 2018
You need to hold the TC button down for at least 5 seconds. Give the link below a once over and familiarize yourself with the cars traction management.
https://www.camaro6.com/forums/showthread.php?t=496996 |
11-19-2023, 06:40 AM | #7 |
Drives: '21 ZLE A10 Join Date: May 2012
you can use line lock which is a PITA...watch the video
https://youtu.be/6S9lLI8vw3M?si=wtsaDJ_5hetj5I24
