Old 11-20-2023, 03:34 PM   #1
jesse121pm
jesse121pm's Avatar
Drives: 2012 Camaro 2ss 45th anniversary
ZL1 Rear End
Where are you guys finding zl1 rear ends for a manual 2012 camaro ss. I see some on hawks but they are $6k I hear all the time people getting them for a good price. How do you guys find such good parts.
jesse121pm is offline   Reply With Quote
Old 11-20-2023, 05:39 PM   #2
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here is one in Ohio but it isn't cheap. A couple years ago I passed on a complete rotor to rotor cradle with calipers for 4k. I am kicking myself now but really didn't need it.
https://www.ebay.com/itm/16643525491...IAAOSw4IFlUjVF
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 11-21-2023, 12:03 PM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
There is a guy on Facebook selling an entire 3.73 rig for 2600, which is way below market. If he is legit and you think it's in good shape, that is about as good a deal as you will find.
https://www.facebook.com/commerce/li...are_attachment
Old 11-21-2023, 01:34 PM   #4
jeff657756
Drives: 2014 SS 1LE
I PMed you yesterday about one in Ohio for $3200. I got mine from the same guy. He has a 3.73 left.
jeff657756 is offline   Reply With Quote
