11-21-2023, 04:46 AM | #1 |
Drives: 2020 Chevy Camaro ZL1 Join Date: Apr 2023
ZL1 Headlights
I am a little confused, does a 2020 ZL1 come with a non upgradable led head light or HID? I would like to have something a little brighter than the stock. After searching, some sites show they are upgradable/compatible?
11-21-2023, 07:10 AM | #2 |
Drives: 2018 Camaro 2SS A8 Join Date: Jul 2017
As far as I know, the ZL1's headlights haven't changed since 2017, they're still the same HID units.
735 rwhp | 665 rwtq Magnuson TVS 2300 80mm pulley | Kooks 1 7/8" LT headers | JRE smooth idle terminator cam | LT4 FS & injectors | TSP forged pistons & rods JMS PowerMAX | DSX flex fuel kit | Roto-Fab CAI | Soler 95mm LT5 TB | 1LE wheels | 1LE brakes | BMR rear cradle lockout | JRE custom tune 1100 - 1/30/18 | 2000 - 1/31/18 3000 - 2/06/18 TPW 2/26/18 3400 - 2/19/18 | 3800 - 2/26/18 4300 - 2/27/18 | 4B00 - 3/01/18 4200 - 3/05/18 | 4800 - 3/14/18 5000 - 3/16/18 | 6000 - 3/19/18 |
11-21-2023, 07:46 AM | #3 |
Drives: 2024 ZL1 Join Date: Apr 2023
I have no idea if they are the same but the headlights in my 2024 are stock and fantastic. I was totally impressed with them driving home last week a couple hours after sunset.
11-21-2023, 09:17 AM | #4 |
Drives: 94 Toyota Pickup Join Date: Jun 2019
I know my 23 still has the HID's, I don't think any of the ZL1's came/come with LEDs.
11-21-2023, 10:11 AM | #5 |
Ok thanks for the response, I wasn’t sure if they had any refresh of sorts
11-21-2023, 11:33 AM | #6 |
Drives: 2023 Black ZL1 Auto Join Date: Oct 2009
Chevy changed the non-ZL1 models headlights to LED when they refreshed the front end. They didn't want affect the aero on the ZL1, so they didn't change the headlamps. That's what read, but they knew the Camaro was being discontinued and didn't want to spend the $$$.
Morimoto also makes D3 bulbs that are an improvement over the stock ones from reading older posts on this. |
11-21-2023, 01:12 PM | #7 |
Going to try the Morimoto 6k. I want a little more white light and get rid of the yellow, they seem to be reasonably priced as well.
11-21-2023, 01:15 PM | #8 |
If it's not too late, I recommend going for a 5500K or 5000K bulb instead. You get the highest lumen output between 5000 and 5500, and the stock unit is 4200K, so 6000K may be too blue next to the standalone DRLs.
11-21-2023, 01:24 PM | #9 | |
https://m.youtube.com/watch?v=2dFzk6Daou0 |
11-21-2023, 03:23 PM | #10 |
Drives: Chevrolet Camaro ZL1 Join Date: May 2022
LED D3S bulbs. I run them on mine and they have considerably improved the nighttime output of the headlights visibility. I'll shoot a link over here to what I used in a while.
2017 Red Hot ZL1 A10 - Apex ARC-8's, 305/ 325 PS4's, DSX 9.06 12% Pulley, NGK HR7 Ruthenium spark plugs, Katech Oil Pump, LME tensioner, DOD delete, Cam, MPI lid, Soler ported 87mm (91mm effective) TB, Granatelli SS plug wires, Cordes LTR reservoir, DMS T-stat housing, Borla X pipe, AFe NPP exhaust, Black Widow Angry Housewife/ Venom 250 mufflers, BMR engine mounts, Banks iDash, Lithium Battery, Course Motorsports phone mount, AEM X- Series, HP Tuners, JMS, E85, 13.6 psi
737 HP/ 779 TQ |
11-27-2023, 02:08 PM | #11 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
D3S is bulb size. I've ran Morimoto 5500K since I got the car June 2021, mainly wanted a whiter light.
When I put the bulbs in, I also installed light smoke Headlight Armor. Between both, on a dark back road I can't tell the difference, increase or decrease, in light output. Morimoto's have been faultless, always come on and never a Popeye. *knock on wood*
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
11-28-2023, 10:11 AM | #12 |
I run a set of the LED DS3 bulbs in my daily and can agree with ZLRob they have done wonders for me as well. I have a year and a half with easily 20-30k plus night miles on them with zero issues.
Morimoto Headlights, AWE Touring Catback, MM Catch Can, ADM V2 Reservoir, Roto-Fab, C&R Oil Cooler, 1LE Grills
11-28-2023, 11:28 AM | #13 | ||
Given the way they look, there are other manufacturers that make the same thing and they look virtually identical. Like I said, night driving is so much better these days after I replaced them over the HID's.
737 HP/ 779 TQ |
11-28-2023, 12:03 PM | #14 |
On dark back roads, do the LED bulbs have same throw as HIDs? Like on back roads where there's no ambient light? That's always the complaint I've heard and experienced about swapping from HID to LED.
