Old 11-22-2023, 10:14 AM   #1
flht99b
flht99b's Avatar
Drives: 2010 Camaro 2SS/RS RJT
Forgeline Performance Series DS3's for sale.
Contemplating changing the look of my car. These Performance Series Forgeline DS3's have been on my car since 2012, approximately 20K miles. No curbing, scratching, look like new. Left rear has a tiny nick in the silver powder coat center, about twice the diameter of a pen point. Fronts are 20x9.5 with IIRC +24mm offset, rears are 20x11 with +45mm offset. Bolt circle is 5x120mm. All 4 tuck inside the fender about 2mm more that OEM 5 gen ZL1 wheels. They are polished outer barrels, powder coat black inner barrels and powder coat silver centers, stainless steel bolts from the back so they are hidden. If someone was interested in the tires and tpms along with the wheels, both tires and tpms were installed new just about 3 years ago. Tires are Nitto NT05, 275/40/20 front and 315/35/20 rear with about ~2k miles on them. First picture shows Vredestein tires, 2nd picture is with Nitto NT05's currently on car. I just priced these wheels from Forgeline and new the fronts are $3310 for the pair and rears are $3360 for the pair. IIRC the fronts are ~24lbs each and rears are ~25lbs each. Looking for $4800 for the wheels alone, wheels w/tpms, tires and lug nuts $5700. Will ship wheels only at buyer expense, local pickup only in Knoxville TN for complete wheels/tires assembly. FYI, I have the ZL1 6 piston caliper and rotors on the front along with Pedders coil overs and wheels clear with room to spare.
RJT 2SS/RS, AAM 3.70's, MTI Sway Bars, Shifter, SS brake lines ZLI calipers, rotors/pads BMR Trailing & Toe Arms, rear cradle/diff bushes, Pedders XA's, Camber/Toe eccentrics, Radius arm inserts, GTO clutch reservoir, LS9 cam, Comp valve springs, Melling 10296 oil pump, CR5 timing chain, LS6 damper, CAI Cold Air Intake, ARH LT headers, HF cats, GMPP axle back, Elite Eng Catch Can, Black ZL1 20x10 & 2011 whls 285/35/20 & 305/35/20 General G-Max RS, 2011 Convertible spoiler, 1LE front spoiler, Lloyd "SS" Floor Mats, GM Camaro Trunk Mat, wrapped console, hand brake lever, Grant steering whl.
flht99b is offline   Reply With Quote
Old 05-24-2025, 09:44 PM   #2
flht99b
flht99b's Avatar
TTT. Wheels, tires, tpms, lug nuts asking $4200. Wheels alone cost $7k new.
Old 08-20-2025, 04:40 PM   #3
flht99b
flht99b's Avatar
I have these wheels and tires off the car and want to sell them. I'll entertain a reasonable offer. Will remove tires from wheels if you prefer to just have the wheels. Come with lug nuts, locks and tpms.
Old 11-02-2025, 03:04 PM   #4
flht99b
flht99b's Avatar
$3500 before they go to eBay.
