Old 11-23-2023, 09:52 PM   #1
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Need some quick input before I order
Happy TG all
I'm about to pull the trigger over @Phastek for an order, just wondered if I'm going with the right stuff, or what I should change to instead.
Thanks Fellas.
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 11-24-2023, 09:49 AM   #2
Infidel67
Life's just a Ride
Infidel67's Avatar
Nobody?
Old 11-24-2023, 10:13 AM   #3
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
if you ever plan to boost those injectors will be a limiting factor. why the sct tuner and not just hp tuners mpvi3.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 11-24-2023, 11:00 AM   #4
Leadsled
Leadsled's Avatar
Drives: 2010 Camaro SS 6MT
Whats the need for the extra fuel? and the tuner? I see that you are cam'd . You should already have tuning software
TSP 229/244 .629"/615" CAM w/ a bunch of goodies 465whp/443tq tuned by MayhemMotorsports-NC
Leadsled is offline   Reply With Quote
Old 11-24-2023, 12:01 PM   #5
Infidel67
Life's just a Ride
Infidel67's Avatar
Which ones should I get instead ? and I will get the HP instead.
If I boost I want to have all other things in order before I do.
I had it tuned by the Guy in Lexington SC, you might know him?
And no I don't have a Tuner yet, So like tartagliazl1 mentioned I get the HP instead.
Old 11-24-2023, 12:11 PM   #6
tartagliazl1
Im currently on 850cc injectors with meth on 17lb of boost. Today i just bought 1300cc injectors so i can run E85 this spring.
Old 11-24-2023, 12:14 PM   #7
Infidel67
Life's just a Ride
Infidel67's Avatar
That was an old screenshot, sorry. These are currently in my cart
https://www.phastekperformance.com/F...s303-0850h.htm
Old 11-24-2023, 12:18 PM   #8
tartagliazl1
https://www.montmotorsports.com/fuel...viously-770cc/
They are not a sponsor so this might get taken down
Old 11-24-2023, 02:34 PM   #9
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
17# on a LSA???
Niccce
joshnmn is offline   Reply With Quote
Old 11-24-2023, 03:37 PM   #10
tartagliazl1
Originally Posted by joshnmn View Post
17# on a LSA???
Niccce
Spin it to win it lol
Old 11-24-2023, 04:02 PM   #11
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
You should change the ship to address to mine lol! Nice list!
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 11-24-2023, 04:31 PM   #12
Infidel67
Life's just a Ride
Infidel67's Avatar
Thank you fellas ! LMAO @ acutron42
Old 11-24-2023, 04:52 PM   #13
Infidel67
Life's just a Ride
Infidel67's Avatar
Had to take advantage of black Friday
Thanks tartagliazl1 for the link, save to take down
Old 11-24-2023, 05:51 PM   #14
acutron42
acutron42's Avatar
Nice choice with the MPVI3.
