Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 11-25-2023, 03:08 AM   #1
jacobcarrasco7
Drives: 2011 CAMARO 2SS
Mcleod Twin Disc and Ram Clutch Slave
I had a question regarding the ram clutch slave. I am installing a mcleod twin disc clutch onto my Camaro 2011 SS w the Ram slave and do NOT wanna mess it up!!!
Looking at the instructions on how to measure for proper fitment. I just wanted to verify that I am doing my measurements correctly because I did not have to use any shims and I got a gap of .195 which is perfect.
For the clutch, is it from the top of the clutch fingers to the bottom of the flywheel? Like the image below! For this measurement I got: 3.634
For the engine measurements, where exactly do I measure? Is it from the crankshaft flange to where that arrow is pointing to (The silver part) or where it is circled? (gray part)
Size:  202.7 KB (not my engine)
For this measurement I got: 0.178 and that’s from measurement from the silver part!
For my last measurement which is the bell-house to the clutch slave pressed down, i got: 4.007
Which B - (A+C) = .195 ( i didn’t have to use any shims!
And you should I also get the ram pedal adjuster??
jacobcarrasco7 is offline   Reply With Quote
Old 11-25-2023, 12:08 PM   #2
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
You might want to ask in this section. There is no "Camaro team" anymore.
https://www.camaro5.com/forums/forumdisplay.php?f=76
Old 11-25-2023, 02:47 PM   #3
jacobcarrasco7
thank you
Old 11-25-2023, 04:39 PM   #4
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Originally Posted by jacobcarrasco7 View Post
thank you
Yes sir! Hope you find what you need..
camaro, ram slave
