Old 11-25-2023, 11:03 PM   #1
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
Hotchkis Sway Bar Setup
So I'm curious about the people that run the Hotchkis sway bars and what their setup is.
I realize there are many great sways out there, but I'm really only interested in Hotchkis users at this point so I can keep the info I receive closest to my situation as possible.
My front and rear are 32mm and only the rear is adjustable. I'm currently in the middle hole on the rear sway and my rear endlink is at 6.5" long. I'm lowered 1" on BMR springs and have factory magnetic ride along with solid cradle bushings, Hotchkis Chassis Max, BMR toe rods and trailing arms. I don't have offset diff bushings. My alignment is at stock specs for the street.
I'd like to know what you guys are your running and why.
Thanks for the info in advance as I always find this learning experience entertaining.
FasNuf is offline   Reply With Quote
