Old 11-27-2023, 10:30 AM   #1
pcguy2u
pcguy2u's Avatar
Drives: 2009 Corvette ZR1
Intermittent no crank and slow crank - mostly starts
Received the below from my neighbor and I'm not able to help him till the earliest Wed. Asked him to check for codes; 2000 Silverado.
Left the motor running for the rest of my trip to Santa Rosa except for once when I accidentally turned it off. And then it started very poorly even with my new battery. So it's obviously not the battery.
I bought a new starter which of course has a solenoid attached and a new relay when I was in Santa Rosa. They said I could bring back the starter if I didn't use it.
On the way home I tried to turn on my driving lights but the LED that shows that they were on just flickered and they only flickered.
About a week ago the wife noticed that the LED that indicates power to my driving lights was flickering. I hadn't noticed it since with my new LED headlights I don't use my driving lights anymore.
So it sounds like a ground somewhere is failing. obviously the solenoid and starter wouldn't affect my driving lights.
Not convinced that it's the ground and I asked him to verify the first 12v- connection to the engine is solid.
Any chance someone has seen something similar and/or can comment on this.
Here's a link to my 70 Chevelle build thread:
https://www.chevelles.com/forums/12-...aro-donor.html
pcguy2u is offline   Reply With Quote
