Old 11-30-2023, 08:18 PM   #1
kgwynn
Drives: 2012 LT
Blend door broken need inverter advice
Hey guys, Im not new but it's been a long time.
The dreaded blend door issue hit me in Michigan and I am aware there is a work around instead of pulling the windshield and dash.
My issue is it freaks me out even thinking about cramming my ample a$$ into that space to fix it.
So I want to temporarily install a power inverter. I tried the plug in 12v lighter version and it didn't work at all. It is not powerful enough for even the weakest heater.
So I want to try one of the ones that hook to the battery.
Problem is, I have a convertible. So running cables through the rear seems difficult.
Any suggestions? Even youtube isn't helping for the first time.
kgwynn is offline   Reply With Quote
Old 11-30-2023, 11:20 PM   #2
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
https://www.camaro5.com/forums/showthread.php?t=573517
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 12-01-2023, 09:39 AM   #3
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Lot's of great details in the link above, including my 2 cents. (last few pages)
"My issue is it freaks me out even thinking about cramming my ample a$$ into that space to fix it." - With the seat removed there's enough room to get your a$$ in there but there isn't much you can do about the cramped quarters under the dash.
In theory, it's a fairly easy fix. I found it to be a pretty big PIA. But saved mucho dinero!
Moto-Mojo is offline   Reply With Quote
Old 12-01-2023, 09:55 AM   #4
gtstorey
So you are planning on trying to run a 120v heater off of an 12v to 120v inverter?
This just sounds like you asking for issues. Maybe look into heated motorcycle clothing.
gtstorey is online now   Reply With Quote
Old 12-01-2023, 10:29 AM   #5
Moto-Mojo
Moto-Mojo's Avatar
"This just sounds like you asking for issues. Maybe look into heated motorcycle clothing."
It's what all the best dressed Camaro owners with busted blend doors are wearing this winter!
Where's that GM Cust Service rep that used to hang here? This is an absolutely stupid fail for such an otherwise decent vehicle. Look what we're reduced to. Your choices are either spend $2000 to $4000 to install a $20 part, depending on your state, crawl under the dash and hack a hole, or go without heat and or air conditioning.
Old 12-01-2023, 02:06 PM   #6
PaulsSS
Drives: 15SS Camaro
Broken blend door you should have more heat than you can take?
PaulsSS is offline   Reply With Quote
Old 12-01-2023, 03:09 PM   #7
Infidel67
Life's just a Ride
Infidel67's Avatar
I was thunking the same, but im not a Vert Owner so I can't comment
Old 12-01-2023, 03:12 PM   #8
bsn
Drives: 2013 ZL1
You would have to find an inverter rated for a higher wattage than what your heater is rated. Its not a good idea due to the chance of a fire if it were to come in contact with anything or fall over. For what you would have to invest in this temporary fix it would probably cost you less to find someone handy to replace it for you, or try to sneak a piece of wire in and open it-you will need to drill a small hole to do that.
bsn is offline   Reply With Quote
Old 12-01-2023, 03:26 PM   #9
gtstorey
I'm not either so disregard my comments. They only apply to 2010 coupe, 2SS, L99, Black, w/added LSA supercharger and located in North Alabama. I haven't decided if the particular county matters. And what about the Sun Roof?
Old 12-01-2023, 07:28 PM   #10
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
Look into this.. I'm pretty sure they are the same for verts and coupes...
https://www.blenddoorusa.com/product...maro-temp-door
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 12-13-2023, 11:32 PM   #11
kgwynn
Drives: 2012 LT
That is def an idea. Never heard of that.
Not sure you read my post.
Been looking for someone. That's also an option.
Also just thought of getting a portable 500w power station. They really aren't expensive. Sounds like it can power a 450w heater.
Old 12-14-2023, 01:07 AM   #12
roh
Drives: 2013 ZL1
Given that a blow dryer is 1500 watts, I wouldn't expect much.
roh is offline   Reply With Quote
Old 12-14-2023, 08:02 AM   #13
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
A 12v heater would probably serve you better and be safer. You won't be pulling extra power into an inverter for voltage conversion.
https://www.amazon.com/AmazonBasics-...1zcF9hdGY&th=1
I own a vert and I can't imagine what would be different under the dash. I see no difference between that an my 2010. Perhaps the broken blend door is not open far enough to provide sufficient heat. Does the blend door affect the amount of outside air coming in.
