![]() Drives: Chevy camaro SS Join Date: May 2020
Can a 103 mm throttle body on existing factory intake maniflod?
I have an existing manufacture's intake manifold, I bought a 103 throttle because my current throttle body hestiate on accleration. the 103 will mount up to the existing manufacture intake manifold however it idles high and it surges. I ask the tuner for a tune but he indicates that it will not work on this size of engine. I was just wondering if anyone tried to upgrade orginal throttle body to 103mm an had success with it? I have a 2010 SS LS3 6.2L
Sincerely, BlackBird1 |
2&THEHIT
Drives: 5th Gen Camaro; 5th Gen Ram 3500 Join Date: Mar 2018
It won't fit on a stock intake. It might bolt up and plug in, but it won't work.
![]() ![]() Drives: 2013 Camaro 2SS AGM Join Date: Apr 2020
This will help you. Nothing to be gained with a 103 on a stock ls3.
https://gwatneyperformance.com/103mm...ow-much-power/
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
#4 | |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
All of the above!! Agreed..
