![]() Drives: n/a Join Date: Jan 2015
1500 miles on BR7EF plugs, rough idle almost stalled
I have a 2013 ZL1 with LT's, 850cc injectors, 2.5" pulley, Flex fuel sensor, tuned and running E60 mostly, running NGK BR7EF plugs gapped to 0.030 I think. It made 622 rwhp on the dyno. For months its run great. About two weeks ago the idle got rougher and it stalled after startup once. Seemed fine for another few days until I took it out last night to bed in some new pads. After decelerating from 80 to 0 it stumbled and almost stalled. It still pulls hard and runs fine driving normal but it just does sound right, like the exhaust note is off.
Is this normal BR7 behavior when the weather gets colder? I'm in FL and it's dropped into the 50's and 60's vs 80's to 100 F. |
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
haha. To the OP. Do you have any codes? maybe a cracked plug. Check your tune file and see if any engine codes are present or maybe your tuner turned off some of the engine diagnostics.
22% lower/ 2.5 upper/ 2 headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5 intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2 lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
#6 |
1 ECM code P0006D-00 (BARO) Supercharger Inlet Pressure Not Plausible
#7 | |
EMT NY
Drives: 2011 Chevy Camaro SS White Join Date: Nov 2023
Fuel
Anything Fuel pressure related? Sean |
#8 |
Check your map sensor and also see if the supercharger bypass valve is working correctly.
#9 |
looks like this will fix it
https://www.amazon.com/ACDelco-213-4.../dp/B004SEKMRU We'll find out tomorrow night |
#10 | |
No fuel related issues. I'm going to replace this sensor 213-4681 and see what happens |
#11 |
I'm going to replace the sensor. I know the bypass valve was adjusted manually during the tune. Not familiar with the process of checking it to see if it's functioning. It makes about 13.5 lbs of boost at the moment
#12 |
[QUOTE=sbelyo;11385167]I'm going to replace the sensor. I know the bypass valve was adjusted manually during the tune. Not familiar with the process of checking it to see if it's functioning. It makes about 13.5 lbs of boost at the moment[/QUOT
Hopefully the sensor fixes your issue.
#13 |
EMT NY
don't agree
If your engine was a year or so earlier I would argue the shut off valve is the issue. Ask infidel67 he was the moderator at the beginning of your thread. If there is a fuel error he would know.
#14 |
![]() Drives: 2013 ZL1 Join Date: Sep 2021
Since your running a stock fuel pump it would be a good idea to look at your plugs while its down to make sure its not too lean, personally I prefer the TR7ix @ .030 for ethanol.
P.S. there are so many counterfeit parts on Amazon if the sensor doesn't correct your problem-it might be worth trying one from a known parts supplier. |
