Old 12-03-2023, 06:23 PM   #1
Izzyd06
Drives: 2010 Chevy Camaro 2lt
V8 harness
I'm about to start my engine swap and want to know if there is a difference between the auto and manual engine harness any help will be appreciated
Izzyd06 is offline   Reply With Quote
Old 12-03-2023, 06:25 PM   #2
PaulsSS
Drives: 15SS Camaro
Seriously? You are asking that and you are going to TRY and swap a v8 in? You are in for it.
PaulsSS is offline   Reply With Quote
Old 12-03-2023, 06:27 PM   #3
Skelly
EMT NY
Skelly's Avatar
Drives: 2011 Chevy Camaro SS White
ifffff
Do both have the 8 already? only two sensors on manual but many on auto
Skelly is offline   Reply With Quote
Old 12-03-2023, 06:56 PM   #4
Izzyd06
It's almost done just need the finishing touches I used a standalone and want to make it look as factory as possible
Old 12-03-2023, 06:57 PM   #5
Izzyd06
No it started out as a V6 auto I have 6.2 l ls and cd009 transmission
Old 12-03-2023, 07:08 PM   #6
SlowLS1
SlowLS1's Avatar
To answer your question, yes they are very different.
SlowLS1 is offline   Reply With Quote
Old 12-03-2023, 07:21 PM   #7
Skelly
EMT NY
Skelly's Avatar
Stop
Did these other so called pros send you here????Look its not feasible at all. From the rear communications ports and battery ending under the rear seat on a LT is the only thing that is remotely similar. The rest from the cluster board that stores your mileage to center console, BCM , Comm port under cover on driver side to front end harness and related to headlights fuel rails ECM , yea I know. All different plus you must also include Bottom side sensors from CAT's to Trans the works. NONE IS COMPATIBLE... Please cancel out this request before asking further.
Old 12-04-2023, 12:05 PM   #8
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
^^^ Wow, where do these guys come from?? I haven't been on for a couple days, but I see we don't have to listen to anymore of this arrogance! Geezz..
Old 12-04-2023, 06:44 PM   #9
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
lol and this dipshit couldn’t even figure out how to put a spoiler on his car. Glad he is gone. OP, I’d love to see your build once you get it running. This swap has been done but it is not easy at all on the electronics side of things.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 12-04-2023, 07:26 PM   #10
tartagliazl1
tartagliazl1's Avatar
Drives: 2013 zl1 vert
well skelly didn't last long. always muddying up people's posts.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
tartagliazl1 is offline   Reply With Quote
Old 12-04-2023, 10:05 PM   #11
PaulsSS
Drives: 15SS Camaro
Not trying to discourage you but others have tried and failed. I can see using a stand alone to run the engine but I'm sure trying to get any of the other systems up and running without the engine computer is going to be extremely tough. I only say this because I've watched others that had advanced knowledge and resources fail trying the same. I'll tell you how I would do it is find a totaled v8 car and simply swap everything. No reason it shouldn't work except the vin not matching the car. Also some states that have emission or state inspection check the vin,s. If they don't match it will fail but maybe your state isn't one of them. If you get it working for sure post it up. Good Luck.
Old 12-05-2023, 05:54 AM   #12
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here is an old thread that is worth going through. https://www.camaro5.com/forums/showthread.php?t=448785
No discouragement here either but it is certainly not plug & play. At the end of the day consider if the juice is worth the squeeze.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-05-2023, 10:27 AM   #13
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
This Moron didn't even had a Camaro! good riddance
Anyway good luck OP with the Swap
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 12-05-2023, 11:19 AM   #14
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
OH, But he said he had two!! Him AND his wife!! LMAO.... Anyway OP, good luck with your project sir!!
