Old 12-10-2023, 01:41 PM   #1
void_kp
void_kp's Avatar
Drives: Chevrolet Camaro Z28 (2015)
where to find z/28 headers in 2023
hey folks, i’m looking for a better exhaust header set with high flow cats for the z/28.
i read a lot about kooks and ach… but it seems like they are hard to find and many posts in this forum about it are quite old.
any advice on where to find good high quality headers for z/28 in 2023?
are you selling some?
2015 Red Z/28.
Seattle area
void_kp is offline   Reply With Quote
Old 12-10-2023, 07:06 PM   #2
bsn
Drives: 2013 ZL1
Any 5th gen Camaro V8 headers will work, unless your tracking the car 1-7/8 is probably the best choice.
bsn is offline   Reply With Quote
Old 12-10-2023, 07:49 PM   #3
spyderbuddy
?????? isnt the LS7 different than the LS3/L99 other than bore
Old 12-10-2023, 07:54 PM   #4
Joe.G
Joe.G's Avatar
Drives: 2014 2SS/RS 6SP Ashen Grey
I believe SS Headers will bolt on but the Ports are slightly different, Will it matter maybe not I guess depends if you are trying to get every last bit of power out of the car. As far as clearance and matching up with the Stock Z/28 exhaust I am not sure. I would look around and try to find a Set of ARH which seem to be pretty popular for the Z/28.
GM 3.91/TrueTrac OEM ZL1 Rims, 6 Piston Brakes & Side Skirts.ACST4 Splitter/Deflectors NPP M2W,GM Short Throw,GPI Ported Rod Mod,BO White PTB,CAI/JRE Scoop, GC Aluminum DS,Stainless Works Ceramic LTH/HiFlo Cats, Hotckis 1" Springs & Chassis Max Brace BMR Adjustable Swaybars,Trailing Arms, Adjustable Toe Rod, LCA & Z28 UCA Bushings Hendrix Solid Cradle Bushings Pedders Radius Rod Inserts Strut tower brace, Moroso Catch Can,SCT X4 Dynosteve,Remote Clutch reservoir,Hero Smoked Tail and 3rd Brake Light, Diode Dynamic SL1 Fog Lights
AeroForce Dual gauge/Autometer pillar mount.
Joe.G is offline   Reply With Quote
Old 12-10-2023, 09:01 PM   #5
void_kp
void_kp's Avatar
i am using the car on track only, also, the LS7 headers don't have the same clearance of the LS3 ones, so I doubt that any header for LS3 will fit on the Z/28.
anyway, I won't gamble with SS headers, I want a z/28 specific one. Any shop you would recommend to buy from?
2015 Red Z/28.
Seattle area
Old 12-10-2023, 09:17 PM   #6
Little Walter
Drives: ZL1
American Racing Headers had to make a change for the Z28 header due to clerance.
Little Walter is offline   Reply With Quote
Old 12-11-2023, 01:28 AM   #7
ariZona28
Give speed a chance
ariZona28's Avatar
The Z/28 already has a very good set of unique high flowing exhaust manifolds so if you're going to upgrade ARH or Kooks are the only ones worth the effort to obtain IMO. If I ever do heads, cam and exhaust those two brands are the only ones I'll consider. Track only? Delete those cats so you don't duplicate the unfortunate engine damage that fellow member Docwra experienced.
ariZona28 is offline   Reply With Quote
Old 12-11-2023, 10:52 AM   #8
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Just ordered 2" ARH headers and high flows from dynosteve and the lead time is only 4 weeks.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 12-11-2023, 12:56 PM   #9
aris
Drives: Z/28
ARH and Kooks both make great headers
aris is offline   Reply With Quote
Old 12-31-2023, 11:17 AM   #10
ASimmons04
Drives: 2015 AGM 2SS RS 1LE
I'm curious, why do you only suggest ARH and Kooks. I understand they are well built but there are other companies out there that make great headers as well. These headers are usually twice as much or more than brands like TSP.
2015 AGM 1LE- Roto Fab intake, TSP Headers, BTR Stage 3 cam- 475 whp - SOLD
ASimmons04 is offline   Reply With Quote
Old 12-31-2023, 11:49 AM   #11
Coz3z3
Drives: 2015 Z/28, 2015 1LE
Those two companies are the only companies that make headers for a Z/28 specifically. TSP and all others do not. SS and ZL1 does not fit our cars.
Coz3z3 is offline   Reply With Quote
Old 12-31-2023, 01:48 PM   #12
void_kp
void_kp's Avatar
in the end I've bought 2" Kooks from Phastek
2015 Red Z/28.
Seattle area
Old 01-06-2024, 08:57 AM   #13
pzero
pzero's Avatar
Drives: 2015 Camaro Z/28 #968 Silver Ice M
Take suggestions from other Z owners it will save you a lot of headaches later.
ARH, Kooks, are made for Z/28. You can go with TSP but clearance will be issue. I have Kooks it’s the middle on the price range. Good luck.
“Smart man learn from other people’s mistake, wise man learn from his own mistake.”
Current Cars:
2008 Honda CRV 2.0L
2015 Chevy Z/28 7.0L
2016 Chevy Tahoe 5.3L
Past Cars:
1976 Chevy Malibu Classic 5.7L
1985 Chevy 2DR 4x4 Blazer 5.7L
1989 Chevy IROC-Z 5.7L
1995 Chevy 2DR 4x4 Tahoe 5.7L
2005 Chevy 4DR Tahoe 5.3L
pzero is offline   Reply With Quote
Old 02-21-2024, 07:16 AM   #14
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
You can buy them right on the Kooks website. That's what I did. IMO it's a waste of time to do headers AND keep the cats. The cats are a bigger restriction. I run the 2" headers and no cats.
Here's my install thread:
https://www.camaro5.com/forums/showthread.php?t=573885
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
