Old 12-16-2023, 02:34 AM   #1
Maxi
Maxi's Avatar
Drives: Chevrolet Camaro SS
Question Looking for an advice about 2010 Camaro SS
Hi everyone,
I am looking for an advice about 2010 Camaro SS.
I have decided to buy 5th generation of Camaro long time ago and finally found one. I went to take a look at it, everything was fine until when we were parking the car after test drive and a warning message showed up that said Stabilitrek Service.
The car has around 31k miles, the owner said it had been sitting for a long time and he filled up with 93 octane gas before test drive (he said he used that gas always). THe car does not have any modifications, only mufflers were deleted. The owner said he connected a scanning device and did not find any codes about that message.
I ma not very familiar with this generation. Does anyone know how bad it is and What I can expect from the car after purchasing it?
Should I even consider to buy it after that warning message?
Thanks everyone for helping!
(just random photo from the internet)
https://www.camaro5.com/forums/attac...1&d=1702712004
Maxi is offline   Reply With Quote
Old 12-16-2023, 07:06 AM   #2
Pops
Drives: 2010 Camaro SS2 2012 C6 vette M6
Originally Posted by Maxi View Post
Hi everyone,
I have been driving 2010 M6 for the past 5 years for roughly 40k mils. Everytime I start the car that shows on my info screen. I have had no problems fom the car. It has been professioally tuned duing my ownership. I have been told not to worry about it. It is not a code in my computer as a malfunction. Hope that helps.
Pops is offline   Reply With Quote
Old 12-16-2023, 10:04 AM   #3
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
I would suspect if it’s been sitting a long time maybe the battery is on its way out. These cars are notorious for doing all kinds of weird things (stabilitrac warnings being one of them) when the battery is on the way out.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 12-16-2023, 10:12 AM   #4
SlowLS1
SlowLS1's Avatar
Gonna need to get a scanner on it that can read all the connected modules. No one can tell you how much it will cost to fix. Could be $200 for a battery , or much more without knowing the fault.
That being said, 31k is pretty low mileage for a driver and should last a long time with proper care. If it was me and the price was right and the car I wanted, I wouldn’t let that stabilitrac stop me from buying it.
SlowLS1 is offline   Reply With Quote
Old 12-16-2023, 10:17 AM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Battery or bad grounds.
chevy pilot is online now   Reply With Quote
Old 12-16-2023, 10:28 AM   #6
PaulsSS
Drives: 15SS Camaro
Pretty simple have the owner agree to have a dealer check it out. 120 dollars or so later you'll have a solid opinion. Otherwise I wouldn't buy it, could be anything.
PaulsSS is offline   Reply With Quote
Old 12-16-2023, 10:43 AM   #7
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Another vote for the battery being suspect.
0stones0 is offline   Reply With Quote
Old 12-16-2023, 10:58 AM   #8
Infidel67
Life's just a Ride
Infidel67's Avatar
Drives: 2011 Synergy Camaro 2SS/RS LS3
Yeah what all others said, this is notorious to pop up about everything.
2011 Synergy Camaro 2SS/RS Ls3, LTH, CAI
Custom Intake, TSP stage-3 111-LSA Cam, RWHP 503/508
Infidel67 is offline   Reply With Quote
Old 12-16-2023, 12:20 PM   #9
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
And another vote for the battery. As stated above, since the car has been sitting a while, chances are the battery is in bad shape. When the battery gets "old", and not used for some time the voltage gets low and then these camaros kind of "freak out" due to the low voltage and show all kinds of lights on the dash, and sometimes they won't idle or drive smoothly. Have them check the battery, charge it if needed, or just have it replaced and you should be fine.
Old 12-16-2023, 03:12 PM   #10
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
I agree with all of the above. Ask the owner for service records as well. They are selling a car with a fault & if they are reluctant to have a reputable shop check it out they could be chasing the problem. On the other hand if they install a new battery or put a charger on it & the fault goes away then all is well.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 12-16-2023, 06:22 PM   #11
The Flash
The Flash's Avatar
Drives: Firebird 95, Equinox 05, Camaro 2SS
@Aqua Blue RS/SS - So right you are!!!
I've learned that the hard way almost nine years ago... and got a refresher course these past two days.
The Flash is offline   Reply With Quote
Old 12-17-2023, 12:18 PM   #12
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Yep, that's why you have to be careful buying a used car. If there is something wrong, and there is a CEL on, or any other "system"error showing, I would not even think about buying it until THEY, the seller fixes the problem. Not good ethics to sell something like that. Buyer beware, know what's going on!!
Old 12-17-2023, 12:33 PM   #13
PaulsSS
Drives: 15SS Camaro
I just bought a used motorcycle......................HAVE A DEALER CHECK IT OUT!
I have bought at least 50 used cars and motorcycles...NONE didn't need something and some needed major work, GET IT CHECKED OUT!
