12-24-2023, 04:26 PM | #1 |
Drives: 2022 Camaro 2SS 1LE Join Date: Nov 2021
Setup my LC-2 Digital Wideband O2 Sensor
So I have my wideband sensor setup and was able to configure it in HPTuners to have realtime readouts. The problem is I think its reading at 1/2 of what it should be. Could the formulas I'm using be wrong?
Here's what I currebtly have set for them both: AFR (input/68.05) + 7.36 = output EQ Ratio (Lambda :(input/1024) + 0.5 = output Anyone have something else you're using currently?
p1sc1 factory box w/ stage 2 intercooler, Lt4 fueling, JMS BAP, lt2 intake, kooks 1/78 longtube headers w/ h/f cats, alky meth kit, thpsi port injection
12-25-2023, 11:19 AM | #2 |
Drives: 2016 1SS NFG A8 Join Date: Aug 2017
Curious as to why you didn't go with the tried and true AEM 30-0334? That is what 90% use on this platform.
2016 NFG 1SS A8
Options-2SS Leather/NPP Perf. mods-Whipple 2.9/Fuel System/Flex Fuel/103mm TB/Rotofab Big Gulp/Cat Deletes/Corsa NPP Per. times- 10.5 @ 137 w/ 1.8 60ft Full weight on 20's 1200DA |
12-25-2023, 12:37 PM | #3 |
This one I'm able to link to my P3 gauge instead of buying another gauge to hookup.
12-26-2023, 08:43 AM | #4 |
Snackbar Tuning
Drives: 2023 SGM ZL1 Join Date: Oct 2016
https://forum.hptuners.com/showthrea...da-Scanner-3-0
This thread might be helpful. I haven't messed with any LC/LM widebands in years since the AEM OBD2 unit came out. But I do recall there was some extra work required to get it to work and report properly. |
12-26-2023, 03:05 PM | #5 | |
