![]() Drives: 2010 Camaro SS2 2012 C6 vette M6 Join Date: Jan 2022
Strut tower brace
I thought abought treating myself to a brace for xmas. All the how to videos show dropping struts, putting on a lift, drilling, snaking bolts,welding. I wanted a simple DIY project. Is there a struct brace that would fit a 2010 M6 Heartbeat SC camaro which is just a bolt on? Thanks.
Life's just a Ride
Drives: 2011 Synergy Camaro 2SS/RS LS3 Join Date: Oct 2013
No Drilling Holes or tapping, just mount it on.
https://www.phastekperformance.com/b...QaAgt4EALw_wcB Oh crap, thats an 11 |
Yeah, the early model year 2010's do NOT have the threaded inserts in the strut tower to bolt a brace to. Unfortunately, you have to go through all that mess to install one.
![]() ![]() ![]() Drives: 2013 zl1 vert Join Date: Dec 2018
What about drilling the holes and using nutserts to bolt in with. No going under the car.
22% lower/ 2.5 upper/ 2” headers/ cat delete/ x-pipe/ 2 gallon x tank/ 100-3 pump/ fic 1300/ dsx aux kit/ 103mm throttle body/ big gulp 5” intake/ meth kit/ prometh lid injection/FI interchiller/ 160* stat/ ngk-7/ msd wires/ elite catch can/ tsp cam/ Che trunnions/ ported supercharger/ 1/2” lid spacer/ cnc,milled ported heads/ brick mod/BMR toe and trailing arms/ 781hp 748 tq SAE @17.3lb on a loaded dyno.
Thanks for your respones and suggestions !
#6 |
The BBOMG fill-in husband
Drives: 2015 2SS/RS 1LE AKA V1LE Join Date: Aug 2010
Even my early build 2011 didn't have the threads either
UPSTATE C5 MEMBER
#7 |
Oh yeah, forgot about that. Mine was built July 2010, for the model year 2011, and had them. I remember checking this out before when it was brought up. So I'm not sure what the cutoff was that they started installing the inserts. Been a while. Thanks.
#8 | |
UPSTATE C5 MEMBER
#9 |
![]() ![]() ![]() ![]() ![]() Drives: 2010 2SS LS3 and 1978 STROKER 383 Join Date: Feb 2018
I used the OEM strut tower brace with TPIS pads. But it is a bit more difficult to drill the necessary holes.
You need to drill vertical holes in the inclined sheets of the shock absorber towers. Today I probably wouldn't do it anymore and use something from BMR.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune. |
#10 |
Check the info sticker on the cars door jam on the driver side, it should list the "build date" there. Mine does. Says July 2010. I bought it in May of 2011.
#11 |
I don't have that one anymore, I have the 2015 in my profile pic. But when I looked up my order status posts with BeckyD it looks like it was built the week of 8/26/10
UPSTATE C5 MEMBER
#12 | |
But I like your sig pic!!
#13 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Turbo LS3 Join Date: Dec 2009
I would not trust a nutsert to hold a strut tower brace. It needs to be through bolted for the clamping force.
2011 Vert - 416/w 230/236 .612/.602 115lsa, 1LE suspension w/32mm rear bar. Z28 diff. Gen6 ZL1 brakes. |
