Old 01-05-2024, 06:14 PM   #1
SlowLS1
SlowLS1's Avatar
Surface prep for Head gaskets and other sealing surfaces
I'm interested to know what everyone's preferred technique for getting surfaces ready for head gaskets. What are you guys doing for oil pan, valley cover, front cover and other sealing surfaces.
Please share what you guys are doing. I'm interested, and could be a good source for future searches...
Thanks!
Brian
SlowLS1 is offline   Reply With Quote
Old 01-06-2024, 04:28 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
A friend of mine told me to go over the block deck with the largest sander you can fit on the deck with fine grit sandpaper and keep it moving. But I'm kind of scared to do that but I probably should. lol
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 01-06-2024, 04:36 PM   #3
1JEWLDSSRS
1JEWLDSSRS's Avatar
Drives: 2011 SS-RS
Whenever I did any block prep back in the day, I just did like joe said, went over all the flat mating surfaces with very fine emery cloth, probably 800-1000 grit and sand it all smooth. I did it by hand. Just make sure you tape off or block off any holes that lead into the engine so nothing gets in there from the sanding. Then after all that I wiped all the mating/mounting surfaces with a cloth wet with alcohol..
Old 01-06-2024, 05:44 PM   #4
SlowLS1
SlowLS1's Avatar
I know for a lot of people, methods are a touchy subject. That's why I was hoping to get a discussion going.
I normally let the surfaces soak in seafoam, hit it very gently with a carbide scraper ( one that I know is flat and doesn't scratch) then wipe clean and go from there. Fine scotch brite to knock down any high spots. BrakeKleen all the surfaces and go from there.
I don't trust myself with any type of grinder or power tool.
I am debating if I should get a or make longboard sanding device to hit it flat. And of course grit is another topic. I've seen people go anywhere from 220 to 2000. People say MLS gaskets need something to bite on....
Of course extra care to keep sanding "grit" out of the motor.
That's why I did this thread, what is the forum opinion on this touchy topic.
Old 01-06-2024, 05:50 PM   #5
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
All I've used on the various builds that I have done is the green Scotch-Brite (R) pad and brake parts cleaner. To this day, never have had a sealing issue with the MLS/Cometic gaskets that I've used. Also, my personal builds are both boosted (~11psi on one, and 16psi on the other.)
-Scott
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 01-06-2024, 06:01 PM   #6
SlowLS1
SlowLS1's Avatar
-Scott
Hard to "hurt it" with scotch brite.
Old 01-07-2024, 07:49 AM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
On LS engines, the MLS gaskets don't leave that much behind so the green pads always worked for me with a little solvent. I'm also not looking for it to be visually perfect like it was freshly machined. If it passes the fingernail test, I'm good. I would be too scared to sand on aluminum engine parts. On old cast iron heads I used to wire wheel stuck pieces of those old header gaskets off. Mind you I'm an old computer nerd, not an engine builder.
Old 01-08-2024, 11:25 AM   #8
joshnmn
2&THEHIT
joshnmn's Avatar
Drives: 5th Gen Camaro; 5th Gen Ram 3500
Agree with y'all... Greenie and a solvent. I use simple green for everything and brake parts cleaner to get rid of everything.
joshnmn is offline   Reply With Quote
Old 01-09-2024, 07:26 PM   #9
SlowLS1
SlowLS1's Avatar
Good info here guys! Anyone else got input? Looks like the green scotch-brite is winning.
Old 01-10-2024, 03:21 AM   #10
Bo White
Bo White's Avatar
I too use Scotchbrite and O'Reilly brake clean
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 01-10-2024, 06:54 AM   #11
SlowLS1
SlowLS1's Avatar
That's pretty clean, just green scotch-brite?
Old 01-10-2024, 07:20 AM   #12
morepowerjoe
Damn that is clean. I might have to go that route as well
Old 01-10-2024, 08:41 AM   #13
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
Here is a good article. Fel-Pro calls for a 50-60 Ra micro inch finish. I have also seen 70 Ra or better for aluminum.
https://www.felpro.com/en-ca/technic...ce-finish.html
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is online now   Reply With Quote
Old 01-11-2024, 10:40 AM   #14
Risingson05
Risingson05's Avatar
Drives: 2015 zl1 m6
I used a green scotchbrite and plastic razor blade with WD-40 to clean the carbon off and used denatured alcohol to wipe it down before installing the head gasket .
791whp 699 ft lbs torque on E30 - ported sc /heads by boost mode racing - PAT G cam /Tune
PB:10.5@135
Risingson05 is offline   Reply With Quote
