01-06-2024, 11:32 PM | #1 |
Tr6060noise coming from transmission area
Hello guys Im having this issure right now that I can’t figure out my 2014 camaro ss is making a noise like a exhaust leak rattle, at first I thought it was the header exhaust gasket but its not, I sort of hear like the noise is coming from the transmission by the clutch area it makes it at all time driving or in neutral with the clutch in or out,it has original luk clutch with 40k miles just had clutch slave replaced with a autozone one, the higher the rpm the more it makes it it also has a new pilot bearing oem too
01-07-2024, 08:01 AM | #2 |
Drives: 2013 1ss Join Date: Jul 2012
you mentioned it happens driving or in neutral and clutch in or out and is engine rpm related. This strongly suggests it has nothing to do with the transmission. Clutch in or out suggests it has nothing to do with the clutch.
Is there a condition that changes or stops it? You mentioned engine rpm changes it, anything else? |
01-07-2024, 11:18 AM | #3 | |
01-12-2024, 02:21 AM | #4 |
Drives: camaro 5 Join Date: Jan 2024
Even though you've checked the header exhaust gasket, other components of the exhaust system could be causing the noise. Check for loose or damaged components, including heat shields, exhaust hangers, and the exhaust pipe itself.
