Old 01-09-2024, 09:23 AM   #1
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
ZL1 Factory Rocker Material
Does anyone know if the factory side rockers are ABS or Polypropylene? Broke 2 tabs removing mine, just the tops came loose. Want to secure them back before painting them. I need to know what adhesive would be best due to the material used. Any help would be appreciated!
MSgt O is offline   Reply With Quote
Old 01-09-2024, 10:36 AM   #2
Bluebagger06
Bluebagger06's Avatar
Drives: 2012 camaro ss
I have broken mine before and always used JB weld. Works like a charm and you can build it up some around the mount to help.
GPI Powered
Bluebagger06 is offline   Reply With Quote
Old 01-09-2024, 11:12 AM   #3
SlowLS1
SlowLS1's Avatar
Phastek list them as being ABS
SlowLS1 is offline   Reply With Quote
Old 01-09-2024, 11:43 AM   #4
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
https://www.harborfreight.com/trim-a...-pc-64126.html
I use the tool to the left of the one with the big circle on the end for removing them, if you are patient with it you can do it without even breaking the clips…
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 01-09-2024, 12:51 PM   #5
MSgt O
MSgt O's Avatar
I used that...freezing cold..and I got impatient..my own fault.
Old 01-09-2024, 12:52 PM   #6
MSgt O
MSgt O's Avatar
Thanks! thats normally my standby as well...but delved in to the world of ABS and Poly plastics...quite interesting actually!
Old 01-09-2024, 02:12 PM   #7
Bluebagger06
There is a video on utube that i use now, You take out the torx screws, then pop out the 3 thats along the lower quarter panel, Then take a rubber mallet and hit the rocker towards the rear of car and drive the rocker panel off the fasteners, then you can see how to pop out the fasteners. I havent broke a mount since doing it this way. I have a kit of extra fasteners in case some break.
GPI Powered
Old 01-09-2024, 02:14 PM   #8
Bluebagger06
i use JB original stuff on everything. I dont trust the so called plastic welds or epoxies!
GPI Powered
Old 01-09-2024, 02:28 PM   #9
MSgt O
MSgt O's Avatar
I did that was well...got impatient, and it was 22f..Im dumb...Thanks Again!
Old 01-09-2024, 10:34 PM   #10
Aqua Blue RS/SS
Drives: ABM #93
lol it happens, the first time I pulled the skirts off my old car I’m sure I broke 95% of the clips. They can be a such a pain in the ass.
Old 01-10-2024, 01:44 AM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
Don't do this. Some of the tabs are reversed and slide off in the other direction.
Old 01-10-2024, 04:09 PM   #12
Bluebagger06
LOL, If you pop the 3 by rear quarter OUT first , there is only one that goes the other way! Even the ones up top of rocker go in same direction. And again i would rather break ONE fastener than the mounts. There is no easier way to do it that i have seen and i have taken mine off numerous times to paint or wrap so i have a good feel for it!
GPI Powered
