01-21-2024, 08:02 AM | #1 |
Drives: 2014 camaro 1le Join Date: Oct 2017
Driver side headlight not working properly
My driver side headlight is shutting off before my passenger side when I lock the door. I have the hid halo stock headlight. Has anyone had this problem before?
01-21-2024, 08:24 AM | #2 |
Drives: 2010 2LT/RS Join Date: Mar 2015
I have never heard of this happening before.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), FRONT/REAR Carbon Fiber Wrapped Bowties, Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Side Faded Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links. Evil Energy Catch Can. |
01-21-2024, 08:52 AM | #3 |
Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
Is this on hi beam or low beam?
01-21-2024, 09:49 AM | #4 |
It don’t come easy.
Not sure if there are capacitors involved with the lighting but, being as they hold a charge for a short duration, it could be one of the lights capacitors failed. So, when the lights switch off, the one with the faulty capacitor would shutdown immediately. No clue if this is the case, just putting it out there.
01-22-2024, 08:46 AM | #5 |
It’s on low. It’s when I unlock the car, and the lights come on for the 30 seconds or so. The driver side will turn off about a second before the passenger side. If I can upload a video of it I will.
01-22-2024, 08:52 AM | #6 |
Not much on the low beam side to trigger them separately. They are fed by the same relay. It has to be a difference in the ballast. Maybe one is starting to fail and I could see a bad ground causing some issues.
01-22-2024, 09:04 AM | #7 |
01-22-2024, 09:23 AM | #8 |
It would help to cut that down to just the section of it cutting off since you can't rewind or jump ahead, but I don't see anything really wrong. The ballast probably have transformers that might be discharging at slightly different rates.
01-22-2024, 11:10 AM | #9 |
Drives: 2010 2SS/RS A6 Join Date: May 2019
The function of the ballast must have changed as it got older.
