01-29-2024, 12:38 PM | #1 |
Drives: Camaro SS Join Date: Jan 2024
Wheel Hop M6
Hi everyone,
Looking for some insight I have 6th gen SS M6. Experience real bad wheel hop on prepped surface. Currently riding on Yokas AD09s, more of track tire rather than drag . From there upgraded to BMR cradle bushing lock out kit and lower trailing arms. Still same wheel hop. Have to baby the throttle or I hop violently. Any suggestions? Continue with suspension upgrades? |
01-29-2024, 02:14 PM | #2 |
Drives: like an old lady Join Date: Jun 2012
put a drag tire on it if you want performance at a drag strip
2016+ camaro: everyone’s first car
01-29-2024, 05:33 PM | #3 |
Drives: 2017 Camaro SS 50th Anniversary Join Date: Apr 2021
Do you have stock tire sizes?
2017 50th Anniversary Edition | P1X Stage 2
DSX Aux Low Side | LT4 high side | Flex Fuel TooHighPsi Port Injection (installed & tuning) CircleD 3K Stall | QA1 CF Driveshaft Forgestar F14 Drag 17x10 NT555R2 305/45/17 Rear Forgestar F14 18x8 NT555G2 235/50/18 Front 10.84@131 w/4.13" pulley ??.??@??? w/3.7" pulley (installed & tuning) |
01-29-2024, 06:54 PM | #4 |
01-30-2024, 07:22 AM | #5 |
Assuming the stock tire for yours was the 275/35/20 then that shouldnt be a problem. I had what i first thought was wheel hop, but it was very likely some computer shenanigans due to having non-compatible tire size combo. But a 285/35 is only about .2" larger.
Just curious what power level you are at?
01-30-2024, 08:03 AM | #6 |
Nightmare
Drives: Your mom crazy in bed Join Date: Mar 2011
1.) Consider getting a true drag radial, as it would actually be more beneficial to your launch as opposed to the street tire. If nothing else, consider looking at an R888R or something similar as that's still better than your typical street tire.
2.) If you're drag racing on street tires - drive around the water box and do a quick spin of the tires to clear debris. Don't waste time with a burnout because it isn't beneficial and you'll just help spread water everywhere, most likely pissing some folks off. 3.) Lower the tire pressure on the street tires to about 30lbs, and drop about 2 lbs every time until you find that "happy" place. Every car will have a different one due to the type of tire/power/etc... I'm sure there's something I've missed...
01-30-2024, 06:15 PM | #7 | |
Yes it was. I looked it up before upped a size, I am well within 3% balance. I am at 462WHP/488WTQ. |
01-30-2024, 06:21 PM | #8 | |
That's what I do. I drive around the water box. I do have decent track tires Yokas AD 09s. Just not drags, next set will be Nittos 555R2. I tried to lower pressure once, I drive car to the track. Didn't help and I was far from home as we have only few tracks in a whole province so no air compressor to pump it back up. |
01-30-2024, 06:54 PM | #9 | |
Nightmare
The 555r2 is a solid choice as well for track duty.. https://www.ebay.com/itm/12627848943...MaAnD4EALw_wcB
02-08-2024, 12:51 PM | #10 |
Drives: 1SS Summit White 6 speed Join Date: Jul 2017
You really need sticky tires for a modded 6 speed
I'd even say get a real drag pack at least for the rear. 18" with rrrII's or mickey thompsons
16 1SS M6 White
Magnuson 2.3 Heartbeat Roto Fab Solo Performance Cat deletes and Axleback Hurst short shifter #'s coming soon Riaction coilovers 1LE sway bars BMR mm BMR chassis brace Flow one 19" wheels wrapped in Mickey Thompsons 02 Z28 M6 35th anniversary 80k miles T-tops Leather Bolt ons Joy to drive this classic every day! Daily Driver |
