Old 02-02-2024, 09:43 AM   #1
BoloYang
Drives: Camaro LT 2012
HELP: "Low Oil Pressure. Turn Off Engine" at RPM X4000-5000
Guys,
Here is the deal : When driving above 90MPH (RPM X4000-5000) I get notice on the screen
When it's less then RPM X4000-5000 the "notice" turn off and all is fine.
Your ideas? Thanks for help!
BoloYang is offline   Reply With Quote
Old 02-02-2024, 03:45 PM   #2
HDRDTD
Is your oil pressure dropping when increasing engine rpm?
Old 02-02-2024, 03:48 PM   #3
Batmanntexas
Batmanntexas's Avatar
Drives: 2012 Camaro SS (2SS)
Have you checked your oil level? Sounds to me like the oil pump is sucking the pan dry at those elevated RPMs before the oil can return to the sump, which would be a symptom of low oil levels.
745RWHP/634RWTQ on 93 @ 10psi
806/676 on E85 @ 10psi
Currently @15-16psi....
COTW 9/8/14
Batmanntexas is offline   Reply With Quote
Old 02-02-2024, 04:06 PM   #4
BoloYang
Yes. around when 4-5K
Old 02-02-2024, 04:08 PM   #5
BoloYang
Yes, oil is fine full, using MOTUL 8100 X-Clean EFE 5W30
Old 02-02-2024, 04:28 PM   #6
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
There could be an issue with the oil pump. Maybe there is a tooth broke in the gear. Or maybe your pick up tube is blocked.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-02-2024, 07:26 PM   #7
Miami_SS
Drives: 2011 Camaro SS LS3
Originally Posted by BoloYang View Post
Guys,
You have the infamous "oil pump" issue found in many 2010-12 Camros. I got this exact warning message before my 2011 LS3 engine grenaded in 2015 and was replaced by Chevy/GM with a 2015 LS3 engine under the powertrain warranty. It hasn't been an issue since because the 2015 LS3 engines have upgraded oil pumps.
I wouldn't push that car too hard because the engine is giving you signs that it's about to go bye-bye. Have a mechanic check your engine ASAP! Also, search this forum for previous owners who had the infamous "oil pump" issue with 2010 - 12 Camaros. Good luck!
Miami_SS is offline   Reply With Quote
Old 02-02-2024, 08:03 PM   #8
BoloYang
Thanks for tip! I got 136K on mileage with 3.6-liter V6 engine -- the infamous "oil pump" issues happend to people with 10-20K mileage 2010 camaros. Already looked into it.
Old 02-02-2024, 09:03 PM   #9
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
He has a V6, I don’t think the LS3 pump issue applies.
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 02-02-2024, 09:15 PM   #10
gtstorey
First should be to put a mechanical gauge on it to check pressures.
Old 02-02-2024, 09:19 PM   #11
Miami_SS
Ok, fair enough but he needs to be concerned.
Old 02-02-2024, 09:26 PM   #12
Miami_SS
Ok, mine grenaded at 52k miles on my LS3 which exceeded the bumper 2 bumper warranty and the dealer (in Los Angeles, CA where I lived at the time) tried to deny me, and after getting GM involved, the PowerTrain warranty was invoked. I believe that you have an internal engine issue and it will cost you $$$ out of pocket if you don't have an aftermarket warranty that will cover it. Again, good luck!
Old 02-02-2024, 09:37 PM   #13
Aqua Blue RS/SS
Drives: ABM #93
I definitely agree, as said above I would manually check the pressures and then evaluate from there. Could be as simple as a bad sending unit or as catastrophic as impending engine failure. Either way definitely not something you want to let slide.
Old 02-03-2024, 02:19 PM   #14
BoloYang
Guys,
Thanks again for replys - on monday i have manually checking the pressures - will keep update.
