Old 02-05-2024, 02:31 PM   #1
crt12ss
Drives: 2012 1SS/RS crystal red tintcoat
Fore fuel system, remote start signal
Hello.
Does anyone know where i can pull a 12V signal to connect to the Fore
pump controller that will activate the pump during the remote start cycle, etc?
My fpcm has been bypassed and the regular keyed signal is connected in the fuse panel under the dash. Im pretty sure that isnt the 'right' way to do it, but it works for now.
During remote start, that circuit isnt live, so i need another wire to get that signal from. (crank but no start, no fuel pressure during remote start cycle)
Thanks in advance
crt12ss is offline   Reply With Quote
Old 02-05-2024, 02:38 PM   #2
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
White/Green wire on the FPCM harness.
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 02-05-2024, 02:55 PM   #3
crt12ss
i tried that with the regular key cycle and got no signal to the fuel pump controller. Is it for remote start only?
Old 02-05-2024, 04:08 PM   #4
NoDakZ/28
NoDakZ/28's Avatar
No, it should send power to prime the oem pump then run once its started. I didn't have a remote start but why would that be any different, I bypassed and removed my FPCM when my 1LE was twin turbo and had my fore system. Shouldn't be any different, my guess is since you are running the power signal from the fuse box is the issue. You should be running the fore panel directly off the battery and you need to run the signal to the green/white wire.
2014 1LE - Sold
Old 02-05-2024, 06:28 PM   #5
crt12ss
My fpcm is still plugged in. I tapped the green/ white and ran out to the signal input on the fc3. The 2nd input is the hobbies switch. I'll try it again with the fpcm unplugged.
It didn't work with it plugged in.
Could the fpcm be "turned off'in the tune?
Old 02-06-2024, 09:18 AM   #6
NoDakZ/28
NoDakZ/28's Avatar
Yes make sure the stock fpcm is off in the tune, mine was unplugged as well. So, what do you have that is getting power from the fuse box then?
2014 1LE - Sold
Old 02-06-2024, 06:47 PM   #7
crt12ss
The fore pump controller is connected to the fuse box
Old 02-07-2024, 11:26 AM   #8
jeff657756
Drives: 2014 SS 1LE
White and green on fpcm is the "correct" way to do it. Will turn on with key and stay on while cranking.
That should go to your fore pump controller "remote 1".
My fpcm is still plugged in. You should tapping BEFORE the fpcm so it being on/plugged in or not shouldn't be relevant
jeff657756 is offline   Reply With Quote
Old 02-07-2024, 12:04 PM   #9
NoDakZ/28
NoDakZ/28's Avatar
Your controller should be getting its power directly from the battery.
Correct
2014 1LE - Sold
