Old 02-08-2024, 11:02 PM   #1
Saffir3
BBL-BEE
Saffir3's Avatar
Drives: Bright Yellow SS 1LE
Is this normal oil pressure at redline for a ss 1le v8?
I dont think this is normal. 3.4 bar? with my v6 when i redline its at 6 bar. Does the v8 have less oil pressure? The car has 98,000 miles on it. If it is low what can i do to fix it.
Nuthin' But Bolt On's: eBay 1-7/8" Long Tube Headers, SLP Blackwing Cold Air Intake, Phastek Race Scoop, 3" Maximizer Exhaust + 3" Muffler Delete In-To 4" Chrome Tips, Taylor "409" 10.4MM Wires.
No Thoughts.......Head Empty
Saffir3 is offline   Reply With Quote
Old 02-08-2024, 11:17 PM   #2
AlisoBob
Drives: Camaro 2SS Gen 5
Thats 50 psi.... which is fine if the oil is at full temp.
What is it at idle?
AlisoBob is offline   Reply With Quote
Old 02-08-2024, 11:32 PM   #3
Saffir3
BBL-BEE
Saffir3's Avatar
at idle its 1.4BAR witch is around 20PSI is that too low?
Old 02-08-2024, 11:34 PM   #4
Saffir3
BBL-BEE
Saffir3's Avatar
But my idle is only at 500RPM
Old 02-08-2024, 11:36 PM   #5
Aqua Blue RS/SS
Aqua Blue RS/SS's Avatar
Drives: ABM #93
You should be fine with those pressures, I’m assuming you are stock engine wise?
ABM #2399 2SS/RS:SOLD
ABM #93 2SS/RS Black Rally stripes, Titanium Interior 4,000 miles: GM GFX side skirts and diffuser waiting on paint, GM dovetail, GM heritage, RPI ZL1 style splitter.
‘87 IROC-Z Iroc blue. all original unmolested with 50K miles.
Aqua Blue RS/SS is offline   Reply With Quote
Old 02-08-2024, 11:37 PM   #6
Saffir3
BBL-BEE
Saffir3's Avatar
Yes fully stock engine wize not even a cold air intake!!!!
Old 02-08-2024, 11:41 PM   #7
AlisoBob
1.4 bar is real close to the lower limit.
If the car is new to you, I'd change the oil with the reccomended 30wt.
If it helps.... good.
If not, you can run 40 wt. in the summer months.
Old 02-08-2024, 11:47 PM   #8
Aqua Blue RS/SS
Drives: ABM #93
I’d keep an eye on the idle psi but it’s not at a point where I’d personally worry a ton with the mileage it’s got and being it is stock. If you were cammed or had other power mods I’d be more worried. Worn cam bearings are one semi common area of internal oil leaks on the v8 cars. As said above you can try changing the oil and see if it helps. Never know, if you didn’t do the last change your self the troglodyte that did could have put the wrong oil in it as said above.
Old 02-09-2024, 02:11 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
I'm not really keen on the bar system but others stated that it is 20 psi. With that being said like Aqua Blue, I wouldn't be too concerned with it being all stock but if it gets below that at hot idle I would be concerned because with everything I've read, they say that your idle pressure is really important. My hot idle pressure is at 34 psi with 10W30 VR Racing full synthetic but that's because I have a high volume pump.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-09-2024, 11:26 AM   #10
AlisoBob
Here's my 2015 SS L99/Auto car. The first photo is a cold start up. The second photo is al full temp. You didn't mention if your car was a L99 , or not. Keep in mind the L99 DOD lifter failures are directly linked to low oil pressure.
Also keep in mind that two cars with identical oil pressure might show different numbers on the gauge, due to tolerances in the sending units and the gauge itself.
If you have a DOD car, either disable it now, or I would step up to the 40 wt. oil.
Failed lifters are no fun.
Old 02-09-2024, 12:21 PM   #11
morepowerjoe
1LE's are ls3 manual only.
Old 02-09-2024, 02:04 PM   #12
Aqua Blue RS/SS
Drives: ABM #93
That’s not really an apples to apples comparison in my opinion, because they use two different pumps. The L99 uses a factory equipped high volume pump because of the extra oiling capacity it needs.
Old 02-09-2024, 05:06 PM   #13
AlisoBob
Nope.... both engines are hydraulic lifter engines... and regardless of the manufacturer any and all hydraulic lifters need aprox 10 psi of oil pressure to function properly.
The OP is very close to this lower limit, if his gauge is reading accurate.
Can some LS3 owners chime in with their hot idling oil pressure numbers, and with what oil viscosity ?
Old 02-09-2024, 05:40 PM   #14
Aqua Blue RS/SS
Drives: ABM #93
Holy crap we have hydraulic lifters???
