Old 01-23-2010, 07:32 PM   #1
Kscott46
Kscott46's Avatar
Drives: 2010 Black SS2, RS, MT
Slp X pipe exhaust question
Need some advice! I currently have SS MT, I have Slp LM II axle back exhaust on now. I was looking to get the X pipe assembly and keep my stock headers. My question is, is it worth it? Will the tone of my exhaust change? Performance gains? I don't think I want to tune it, for the reason that my dealer is a SOB, and don't want my warranty voided. I will probably get headers later on, will putting headers or the x pipe throw any codes? Any help would be appreciated! Thanks guys, and here's a link to the x pipe I think this one is it, there are two assembly though:
http://www.LMPerformance.com/53928/119.html
Kscott46 is offline   Reply With Quote
Old 01-24-2010, 04:19 AM   #2
Iwantone2
Voice Of The Voiceless
Iwantone2's Avatar
Drives: CGM 1SS RS
Not sure if this will answer your question, but from what I have read there is little performance gain on the LS3's with exhaust modification. The x-pipe may give you a bit better performance over the stock h-pipe, but may not be noticeable. The x-pipe should not throw any codes, but not sure on the headers.
May you also consider the Magnaflow x-pipe:
http://www.autoanything.com/exhausts...A2672A0A0.aspx
Old 01-24-2010, 09:23 AM   #3
SSTony
SSTony's Avatar
Drives: SS Camaro
Send a message via AIM to SSTony
xpipe might give you some gian but the LT headers and high flow cat is what you really need to have.
SSTony is offline   Reply With Quote
Old 01-24-2010, 12:02 PM   #4
Kscott46
Kscott46's Avatar
Hey thanks for the responses guys! High flow cats? Is that something different than headers? Is that a different type of assembly that would go in between the headers and the axle back I have now?
Old 01-24-2010, 12:12 PM   #5
SSTony
SSTony's Avatar
Drives: SS Camaro
if you get long tube headers you can buy it with it. Kooks sells there headers and cats that bolt right to the stock xpipe. i did it myself on jack stands. i did it myself so imagine how easy it is with a friends hand to help.
Old 01-24-2010, 12:26 PM   #6
Kscott46
Kscott46's Avatar
Yea I heard about Kooks and that they are great, I also just ran into a post of someone doing all SLP, LT's, Cat X pipe, and it sounds killer! The only thing is the setup is like 2 grand, and I have to do this in stages, so I would have to buy x pipe first, now I need to find out if I can buy them seperate. Now is it the X pipe that is catted or the headers? Sorry for the newbie questions! My first sports car! lol
Old 01-24-2010, 03:16 PM   #7
axis
Search Ninja
axis's Avatar
Drives: 2010 Black 2SS/RS A6
I think you need to do a LOT of research into what you're wanting, what each piece is, and how it affects performance and sound. Anything that you buy for your exhaust now will likely be replaced later on with a full system, unless you plan on piecing it all together and having a shop fill in the gaps.
Halltech CF 102 fed
GPI modded intake manifold
Bo (knows) White ported TB
Kooks LT's/ Dynomax VT
Pfadted (springs/sways)
Dyno tuned by Rhino and GPI
Old 01-24-2010, 03:22 PM   #8
Russell James
Russell James's Avatar
I wouldn't mess with it until your ready to do LT headers. The OEM pipes have an equalization H-pipe already. The main performance loss is in the factory cats so close to the heads. They have to be in that location for early fire off and effeciency thanks to greenie folks like Al Gore.
If you messed with the X pipe and cats for the stock manifolds, then going to need a different set up for when you get the LT's. I'd leave it for now.
Old 01-24-2010, 03:23 PM   #9
Kscott46
Kscott46's Avatar
Thanks for all the help guys !! Ill keep researching my options..
Old 01-24-2010, 05:06 PM   #10
tjbusa
Serious Sleeper
tjbusa's Avatar
Drives: 2010 CGM 2SS/RS M6
Another plus is when you buy the header package at once, its a whole lot cheaper than a piece at a time. http://www.camaro5.com/forums/showthread.php?t=58363
Drive-by
Fact of Life:
After Monday and Tuesday
even the calendar reads...
W T F
tjbusa is offline   Reply With Quote
Old 01-24-2010, 06:07 PM   #11
Kscott46
Kscott46's Avatar
Thanks tjbusa! I'll see if I can muster up the courage to drop 2k on exhaust! Lol
Old 01-24-2010, 10:36 PM   #12
linkwpc
The punching cat
linkwpc's Avatar
Drives: '10 Camaro SS Black W/Hugger&W/IOI
I got that xpipe and I can fell the extra power and it sounds pretty good to me!
My car build (COTW 7/23/12) - - - - - - > CLICK HERE! : http://www.camaro5.com/forums/showthread.php?t=80725
linkwpc is offline   Reply With Quote
Old 01-24-2010, 10:43 PM   #13
1521
Drives: 1968conv.,1968coupe, 2010camaross
sounds great you only replaced the h with the slp xpipe, sorry didnt read everything , haha, love the video
1521 is offline   Reply With Quote
Old 01-24-2010, 11:08 PM   #14
JHart
I haz camaro again :)
JHart's Avatar
Drives: 2010 Chevrolet Camaro 1SS
does the slp x-pipe come with resonators?? in the pictures i've seen it does.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd)
2010 camaro1ss(sold, missed, will have another someday)
JHart is offline   Reply With Quote
OK...I'm starting a better V6 exhaust examples thread!! KMPrenger Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 612 09-06-2024 09:00 AM
2LT exhaust options Guardian1816 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 01-12-2010 10:28 PM
Exhaust Question? kutch720 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 3 06-28-2009 02:36 PM
Exhaust Question? kutch720 Camaro V6 LLT Engine, Exhaust, and Bolt-Ons 4 06-28-2009 11:04 AM
Question: LT Headers to 2.5 Exhaust RyanG Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons 3 06-21-2009 08:29 PM
