Old 02-12-2024, 03:53 PM   #1
Saffir3
BBL-BEE
Saffir3's Avatar
Drives: Bright Yellow SS 1LE
Lifter tick around 2800RPM?
I have a 2014 Camaro SS 1LE with an LS3 engine. this ticking is mostly audible around 1k-1.2k RPM. It is extremely audible around 2.8k RPM. IDK what it is it sounds too slow to be lifter tick. can anyone help
here is what it sounds like under the car and from the engine bay: https://youtu.be/0Ph4iD4sGCs
Nuthin' But Bolt On's: eBay 1-7/8" Long Tube Headers, SLP Blackwing Cold Air Intake, Phastek Race Scoop, 3" Maximizer Exhaust + 3" Muffler Delete In-To 4" Chrome Tips, Taylor "409" 10.4MM Wires.
No Thoughts.......Head Empty
Saffir3 is offline   Reply With Quote
Old 02-12-2024, 05:56 PM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
What's your oil pressure when you engine is hot? No such thing as a stupid question around here!
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 02-12-2024, 08:41 PM   #3
Saffir3
BBL-BEE
Saffir3's Avatar
My HOT IDLE oil pressure is between 1.4-1.8 BAR depending on how hot oil/outside is
& my oil pressure is 2.8-3.5 through the RPM range BAR also depending on how hot oil/outside is.
That youtube video dosent do the ticking justice its loud, I can hear it inside the car with my windows down
Heres a picture of my dipstick please let me know if this is alarming
Old 02-13-2024, 12:45 AM   #4
morepowerjoe
Well I'm not a V6 expert by any means but that oil pressure seems really low to me. I'm assuming that the V6 oils the top of the engine first like a LS engine and if it does then I wouldn't think that is the issue but it couldn't help your lifter problem either. Definitely sounds like a lifter and probably better to get it fixed immediately before it breaks because that kind of break van ruin your entire engine. And if you do have the lifter fixed I would also have the oil pump replaced with a high volume pump. Hopefully someone else will post what they think as well like a V6 owner.
Old 02-13-2024, 12:47 AM   #5
morepowerjoe
Another thing is that video you posted looks like V8 not a V6 like in your signature.
Old 02-13-2024, 08:22 AM   #6
MSgt O
MSgt O's Avatar
Drives: 2012 Camaro 2SS/RS Vert LS3/M6
I have a 2014 Camaro SS 1LE with an LS3 engine. Right in his first post MPJ. I saw his signature as well...
MSgt O is offline   Reply With Quote
Old 02-13-2024, 08:52 AM   #7
Saffir3
BBL-BEE
Saffir3's Avatar
I have a v8 ls3 i just havent updated my signature
