![]() Drives: 2010 Chevy Camaro 2SS coupe (MT) Join Date: Jan 2024
No way to tune around O2 sensor CEL’s?
Due to the recent emissions lockout, I was only knowledgeable of the fact that only standalone ECU tuning was the only other way around O2 CEL’s. And since most tuners and handheld (flash) tuners don’t offer any way to disable CEL’s and emissions-related parameters, am I stuck with my car in a “limp mode”, if I am running something like a primary cat delete, or long tube headers without cats or the secondary/downstream O2 sensors plugged in AND rigged up somehow (aside from running cats)?
I guess my only options right now, are to either run shorty headers (CARB legal) and install Solo high flow cats or stick to a 2nd cat delete; neither of these have triggered any O2 CEL’s in the past, at least for me anyways. I’m planning to run some high flow cats with my long tubes, which have O2 sensors; and I’m planning to run the downstream O2’s AFTER the cats, which should theoretically keep the O2 CEL’s off and not triggered. I guess I could also “trick” the O2 sensors with some “simulators”, if needed, but I’m trying to currently run some high flow cats anyways. This was just in the case that I needed to have my car/engine tuned, and couldn’t be under the assumption that I had no cats (catless) or was running non-emissions level cats (sub-200 count cell high flow cats). Anyone else have anything else to teach and/or inform me? I’ve also used old handheld tuners, but if anything, those lacked some things the new flash tuners adjusted; not to mention those also had NO way of tampering with the O2 CEL’s, so that wasn’t a viable option either…. |
![]() ![]() ![]() Drives: 2010 Camaro SS , 2011 Colorado LS1 Join Date: Jan 2022
HP Tuners is your answer. Those codes can be disabled by it.
It can disable emission related codes, and be used to optimize performance by a skilled individual.
A legend in his own mind
Drives: 2010 2SS/RS M6 Join Date: May 2013
My CEL from my lack of cats / o2s was dealt with my tuning by Trifecta. Zero issues since the tune and I pass inspection every year in NY
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads 2006 Dodge Magnum RT "The daily" |
#4 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 Camaro SS2,L99, LSA SC Join Date: Aug 2017
#5 | |
I still use the old MPVI2 and a pretty old software version. Pretty sure this wasn't a thing then...
#6 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2SS/RS Join Date: Sep 2008
Hopefully someone here who lives in California can chime in and give some direction on what they can and can't do. |
#7 |
I’m aware…. People do still use flash tuning software for offroad purposes only, so, we’ll keep it at that.
#8 |
#9 |
Started#gottalovethatblue
What you're asking for and what you're looking for are two completely different things. The rear O2 sensors can be tuned out, but they cannot be deleted from the factory programming. At the end of the day, if you're dead set on staying in California, the best you can do is shorty headers and high flow cats. Best of luck in your quest!
#10 | |
I also have a spare stock set of L99 downpipes (second part of the factory exhaust manifolds/headers), but they do have a 2nd cat delete, with the cat basically gutted. No, it doesn’t throw any O2 CEL’s ofc, but I was wondering if anyone else knows if somehow I could fail otherwise, besides emissions parameters via the OBDII/ECU emission system checks? CA hasn’t used sniffers in almost over 2 decades I believe… Last edited by TheBrightSide; 02-13-2024 at 03:59 PM. Reason: Missing info |
#11 |
Big Crow
Drives: '13 ZL1 Join Date: Mar 2017
I didn't know they disabled the o2 on hp tuners, learn somethin new everday.
Yes they plug in and fail if there is any slightest change from stock tune, so as you might know no such thing as disable and pass. If you reflash your tune back and forth by the time you get enough smog things to say ready it will say cats fail if you don't have them. IDK if your halfcat setup will be good enough if you flash back, the second question how do you not get a cel if you go back to low perf cats will be trial and error. Last edited by silversleeper; 02-13-2024 at 05:14 PM. |
#12 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2010 CGM 2SS/RS LS3 Swapped A6 Join Date: Sep 2016
Wow. I had no idea this was a thing now. I knew EPA was going balls deep on some big tuners, especially the diesel guys, but this comes as a surprise.
| Tags |
| emissions, oxygen, sensor, tuner, tuning |
