Old 02-24-2024, 11:18 PM   #1
SS_Dave
SS_Dave's Avatar
Drives: 2011 Camaro 2SS/RS
Valley cover seal
What all actually has to come off to remove the valley cover for replacing the seal? Debating if I want to do it myself.
SS_Dave is offline   Reply With Quote
Old 02-25-2024, 02:36 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
It's not as bad as you would think but does take some patience. The hardest part is taking the two rear bolts off of the intake manifold because they only come out about 3/4 of the way out and then hit the cowl above it. The best way I have found to help me is (after you loosen the bolts all the way of course) is to put a piece of tape around them to hold them up while you pull the intake off. Other than that it's a matter of disconnecting the fuel live, unplugging all the sensors, vacuum line, removing the intake box (I believe), and the vacuum hose off of the back of the intake manifold for the brake booster and which you will have to pull the intake up and pull forward and set it back down in order to reach it. If your truly going to try and tackle this thing I would invest in All Data DIY. https://www.alldata.com/diy-us/en
It will give you all the information you will need for the gasket replacement. Let me know if you have any other questions.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
