Old 03-02-2024, 06:15 PM   #1
TheBrightSide
Drives: 2010 Chevy Camaro 2SS coupe (MT)
09-13 Cadillac CTS-V/14-15 Chevy Camaro ZL1 BBK conversion on 10-15 SS stock wheels?
Will any 09-13 CTS-V or 14-15 Camaro ZL1 BBK setup fit any 10-15 Camaro SS stock/OEM 20” wheels? I hear that a minimum of 5 mm hubcentric shims will work; and in the worst case, maybe 10-15 mm hubcentric wheel spacers.
In that case, I might be better off getting +35 or less offset wheels for the rear, and like +25 wheels for the front. I found a set of 6th gen SS 1LE staggered wheels, and the front is something like 20x10, +20, so I think I can comfortably run something like that with the CTS-V/ZL1 BBK upgrade.
TheBrightSide is offline   Reply With Quote
Old 03-04-2024, 05:53 AM   #2
TheBrightSide
Anyone..?
Old 03-04-2024, 07:48 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Anything more than 5mm spacer and you need longer wheel studs unless you like to live dangerously.
I realize you are probably looking for someone who has used the BBK wheels already, but you might get more responses if you include the wheel size and offset as some might have done something similar. I can tell you there is no difference between the required offset for a ZL1 of any year and an SS of any year, i.e. ZL1 wheels work just fine on SS cars. I run ZL1 wheels on both my SS cars. 305 square set up on one and 295/325 on the other.
bbk, brakes, cts-v, upgrade, zl1
