![]() Drives: 2011 Chevrolet Camaro SS A/T Join Date: Aug 2022
Hi guys,
In the place where I live only 87 gasoline is available, and it’s a long way to go for Midgrade and Premium. The ambient temperature during this month varies from 23F to 51F. If it’s cold, in the mornings it happens that the car starts and stalls after a few seconds (second attempt is always good). Today it happened that when I started it from the remote key, the engine stalled in 4 minutes (antifreeze 123F). This winter I have already completely replaced the spark plugs twice. They were always found black, but not as a result of oil consumption, they were not shiny. I own this car for 3 years and only this year started my issue with black spark plugs . In January 2023 I pulled heads and cleaned combustion chamber and valves. Also I clean injectors every 3 month. So I have a couple of questions, Could my problems be caused by low-quality 87 ? Can Marvel Mystery Oil or Octane Booster solve this problem? What could be the cause of black spark plugs? MAF sensor is good, injectors are clean. |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: LT W/2LT,blue metallic Join Date: Jul 2016
izzat carbon? i dont think 87 octane is doing your engine any favors,especially if youve already had to pull the heads and clean the chambers.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 Chevrolet Camaro l99 Join Date: Aug 2020
Yeah I know it might get expensive but I would at least add an octane booster before you fill up each time because these cars weren't designed for 87 and I would change those plugs right after you use the booster and drive it for a few miles to get all that 87 out there. Now on which one to use because you don't want to go over 93. Something like this will get you to 91 with two bottles.
https://www.amazon.com/Rislone-4747-...ps%2C82&sr=8-8
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817 |
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
Runs very rich.How long do you drive every day ?
#5 | |
Life is short, drive it like you stole it! ![]() |
#6 |
I'd start with checking compression and codes. Not all codes show up on the CEL. Running on a lower octane will cause the engine to knock under load which causes the ECM to lower the spark reducing power. If enough knock happens, damage occurs. It's possible the MAF sensor is dirty or having issues making the car think it's lean and adding more fuel.
#7 | |
#8 |
#9 | |
What are the reference compression readings for L99 ? I searched everywhere and can't find anything. I checked compression before this issue 1.5 years ago. I found from 116psi to 203psi (except cylinders 6 and 8 because of bad access). |
#10 | |
https://www.ebay.com/itm/175709333796 https://www.ebay.com/itm/114390590368 |
#11 | |
L99 is 10.41 compression on a stock engine so I assume yours is. Make sure all the plugs are out and the TB is wide open to allow air into the engine. Disable the ignition system. 4 compression strokes are needed for a good test. Minimum compression shouldnt be less than 70% of the highest reading.
#12 |
I've seen that the atmospheric pressure x compression ratio is a good rule of thumb. so if youre around sea level that puts you around 150psi. 14.7x10.4=154.
The book did use 150psi as an example,, but not a hard spec.
#13 |
It's just weird to me that the car stalls after warming up a little. I doubt its a compression problem,, but you said the LTFT's were good? What were they? It almost sounds like the car doesnt like going into closed loop.
#14 |
What is sparkpark plug name and type ?
