Old 03-19-2024, 12:43 PM   #1
terry_b
terry_b's Avatar
Drives: 2014 2SS/RS 1LE
Send a message via MSN to terry_b
Question Some suspension repairs incoming... Advice?
Simple question up front: if I'm replacing most of the rear suspension components because of wear (control arms, knuckles, and toe/trailing arms, as well as shocks), should I also go ahead and replace the subframe bushings? I have the "better" 1LE stock bushings plus Pedders inserts currently installed. Think these are worn enough to replace?
Last summer I got hit by a clueless driver leaving a parking lot. I *almost* avoided it, but he ended up tapping the driver's side rear. His front bumper hit the edge of my wheel and the rear bumper. Bumper cover mostly buffed out, no other permanent damage besides a slightly bent trailing arm bolt. I got it aligned, replaced the rear camber/toe bolts - but then we found out a bunch of the spherical bushings were shot. Trailing arm and rear knuckles both had bad bushings.
So, on top of that, I'm at the point where everything is feeling loose and unsettled. Clearly, 98k miles in, my rubber bushings are also all pretty worn. I put Pedders coilovers in probably 50k miles ago, and the right front strut is leaking oil. The springs are also corroded and losing paint (thanks New England winter). So in my garage I currently have the full set of rear control/trailing/toe arms (OEM) and a set of Xa Coilovers to be delivered later this week. I have new rear knuckles, since those spherical bushings are bad and 4 new hub bearings (hopefully these are the correct ones, they look like the right SKF bearings, but they are from eBay).
I also ordered a set of BMR motor mounts, but I don't think mine are bad.they aren't leaking oil at least. I do have an odd vibration that I'm hoping will be solved by the time I get all these parts in. Vibration is really noticable around 75-80 and I can feel it in the steering wheel and with very light brake pressure it gets worse, then mostly disappears on hard braking. According to my mechanic, tie rods seem fine. Outers were replaced a couple years ago, never touched the inners though.
I also plan on checking out the driveshaft coupling, but I understand that is a near impossible to find part - actually, anything OEM is showing "unavailable", out of stock, or "discontinued".
I know it's fairly slow here these days, but I would appreciate any advice you can give, especially if you read through my whole here 😂.
I'm "stuck" with this car for a while, since my wife rolled a bunch of negative equity into hers.... but I won't complain!
terry_b is offline   Reply With Quote
Old 03-19-2024, 04:45 PM   #2
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
You seem to have a good idea of what needs to be done. Z/28 bushings would be a good upgrade. I don't know if they can be found though. Driveshaft, don't worry about it. I'm at 78k my car has had 460wtq for the majority of its life now has over 800whp.
I'd upgrade the rear suspension, new trailing arms and toe links. Might as well. Not expensive.
Replace it all at that 100k mark.
Old 03-28-2024, 09:09 AM   #3
trashbasket
trashbasket's Avatar
Drives: 2010 Camaro
Yes. All the things you are replacing bolt to the rear cradle which is wobbling around on the car with those rubber bushings even with inserts. I would go solids to maximize returns from your other parts. I didn't notice any NVH from going to solids. Diff bushings on the other hand....
Here is a vid to put that subframe movement into perspective and this is with upgraded poly bushings. There is a video of the stock one, but I can't find it.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
trashbasket is offline   Reply With Quote
Old 03-30-2024, 09:33 PM   #4
terry_b
terry_b's Avatar
Well I got everything replaced: rear control arms - both upper and lower OEM, toe links - spherical bushings but not OEM, OEM trailing arms and a full new set of Pedders Xa coilovers.
I have BMR motor mounts and diff bushings, along with a new OEM trans mount - but after 10 hours I'll wait on those. I had to cut the LCA camber adjustment bolt on both sides because it had rusted to the bushing insert and would not move. Luckily I already had new camber bolts ready, but was a real pain.
Already feels much much better, gotta get it aligned Tuesday and then let it all settle in. I really should have gotten solid subframe bushings (not that I would have had the time today) because the little hat on my larger set is rusted out. That probably a squishy mount now.
Anyone happen to have those little hats/washers handy as a takeoff?
Old 03-30-2024, 09:40 PM   #5
terry_b
terry_b's Avatar
Every spherical bushing was shot, and everything is rusted like crazy underneath. Thanks new england!
Old 03-30-2024, 09:44 PM   #6
terry_b
terry_b's Avatar
Old 03-31-2024, 10:04 AM   #7
trashbasket
Drives: 2010 Camaro
Good lord, yea it looked rough. Good work, looks much better and I'm sure it feels the same. If those diff bushings are anything other than stock ones I would NOT replace them unless you are launching hard or in danger of breaking axles. You will have no way of knowing if you have a "quiet diff" until you do them and probability is that you do not. Unless you REALLY need poly or god forbid solids there, stay stock on diff bushings. Unless you just like race car noises.
Old 04-01-2024, 05:21 PM   #8
terry_b
terry_b's Avatar
Thanks for the heads up on the diff bushings. Honestly I haven't done them yet because of the effort involved, but I have read a few horror stories about nvh after doing them. Mine are definitely looking a little worn, but by no means are they dead yet, so I'll probably stick with them until I HAVE to change them.
Car is night and day. Either Pedders changed something or I may have had a touch too much preload in the original install, because I consistently came up with about 5mm difference when setting the coilovers height. The car definitely sits a little higher, and I expect some sag as the springs settle in, but it feels great now and will only improve after the alignment.
Old 10-22-2024, 09:45 PM   #9
dlink
dlink's Avatar
Drives: 2012 Camaro SS 45th Anniversary LS3
Curious did these upgrades ultimately completely remove the vibration in the wheel you were feeling?
dlink is offline   Reply With Quote
Old 08-24-2025, 01:07 PM   #10
terry_b
terry_b's Avatar
Late reply - ultimately there's still a little vibration at highway speed. I feel it in the steering wheel and somewhat in the dash. I am 99% sure it's tires and brakes though. I can get the vibration to go away or at least get better by doing a few hard braking passes after everything is warmed up.
New brakes and tires will be on the way soon - assuming I can justify keeping the car after the most recent development...
bushings, pedders, subframe bushings, suspension
