Old 03-27-2024, 10:37 AM   #1
skippy01
Drives: 2011 Camaro SS
Oil message on dash
So started my 2011 SS and the message can up low oil need to fill I checked and the oil level was good on the oil stick any help would be greatly appreciated.
skippy01 is offline   Reply With Quote
Old 03-27-2024, 01:05 PM   #2
FasNuf
FasNuf's Avatar
Drives: 2014 Camaro ZL1
maybe you need a new one of these. check the wiring too.
12603781
https://www.rockauto.com/en/moreinfo...t=5700&jsn=644
FasNuf is offline   Reply With Quote
Old 03-27-2024, 01:27 PM   #3
skippy01
Ok thank you i was thinking life a oil pressure sending switch but i will try this and see if it fixes it. Thanks for your help.
Old 03-27-2024, 02:30 PM   #4
InFiD3ViL
InFiD3ViL's Avatar
I had no idea these cars even had a Low Oil notification/light
Old 03-27-2024, 02:36 PM   #5
FasNuf
FasNuf's Avatar
Me either until I found this level/temp sensor in my pan. I've never seen a light , but I think it shows up on the DIC.
Old 03-27-2024, 02:38 PM   #6
FasNuf
FasNuf's Avatar
You said the display said "Low oil need to fill" , that doesnt sound like a pressure warning to me. They would tell you to shut the car off immediately if I remember right.
Old 03-27-2024, 07:09 PM   #7
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Even my 02 Silverado has an oil level sensor on the side of the pan. Pretty common on LS.
Old 03-27-2024, 09:51 PM   #8
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Good to know I guess but the dipstick is still my friend!
Moto-Mojo is offline   Reply With Quote
Old 03-28-2024, 03:07 AM   #9
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
A while back I had only put in like 4 quarts of oil in my car to start it and flush it, on the display it said low oil but didn't say shut the engine off.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-28-2024, 06:30 AM   #10
FasNuf
FasNuf's Avatar
It doesn't say it when oil level is low, only when there's no oil pressure. Different sensor.
