Old 03-27-2024, 10:24 PM   #1
matthew9440
matthew9440's Avatar
Drives: 2010 Camaro 2SS/RS
Corvette C7 Z06 REAR Calipers
I just purchased a set of Corvette C7 Z06 calipers. I'm going to send them out to powdercoat. Has anybody also used the rear calipers from the Z06? I bought this set, because I thought I understood that these would all work. Then I read through threads where most guys just go to the 6 piston front and use the stock calipers on the rear or ZL1 rear calipers. Can anybody verify if these Z06 rear calipers will work?
matthew9440 is offline   Reply With Quote
Old 03-28-2024, 04:13 AM   #2
morepowerjoe
morepowerjoe's Avatar
Drives: 2012 Chevrolet Camaro l99
The rears look a lot like the 5th gen rears. May be best to dry fit them to be sure.
DSS Pistons, Eagle ESP L19 Rods, ARP Head and Main Studs, TSP PRC CNC Ported Heads milled .030, Cometic .040 Head Gaskets, GPI SS3 VVT Camshaft, GM Racing Lifters, CHE Trunnions, Melling 10355HV Oil Pump, Cold Air Inductions CAI, Fast LSXR Intake Manifold, Nick Williams 103 TB, TSP Longtubes, ZL1 Fuel Pump, Mishimoto Radiator and Oil Cooler, 3600 Circle D Converter, Tru Cool 40k Tranny Cooler, Fluid Dynamics Balancer, EBC 3GD Rotors with EBC Bluestuff NDX Pads, Bilstein B6 Shocks / Struts with Eibach ZL1 Drop Springs
Build Thread https://www.camaro5.com/forums/showthread.php?t=609817
morepowerjoe is offline   Reply With Quote
Old 03-28-2024, 09:26 AM   #3
Fanch1LE
Fanch1LE's Avatar
Drives: 2015 1SS 1LE
Should be good to go. Can't guarantee it, but logic would say if the Z06, ZL1, CTS-V all use the same 6-piston front, then GM did not spec different size calipers for the rear of these variants. I'd send it to powder coating without hesitation.
Fanch1LE is offline   Reply With Quote
Old 03-28-2024, 08:43 PM   #4
olblue75
olblue75's Avatar
Drives: 2010 2SS/RS
Rears won’t work because of the offsets of the rear knuckle.
Orange Krush II
