Old 03-29-2024, 05:14 PM   #1
SRB
Drives: 2013 Camaro SS
Strut Tower Brace
Does a Strut Tower Brace really do anything for handling or is it just for looks?
SRB is offline   Reply With Quote
Old 03-29-2024, 05:52 PM   #2
redcoats1976
i have one,but i dont think it does much at normal speeds.great place to hang the christmas lights or dry a wet bathing suit though...
Old 03-29-2024, 06:07 PM   #3
SummitWhite11
SummitWhite11's Avatar
Drives: 2010 2LT/RS
For me it's hard to remember. I did this as my first "suspension" mod until I got all serious and did more suspension work as you can see in my profile. How I look at it, It doesn't hurt and yes it looks cool under the hood if you get it painted and add some color.
2010 2LT/RS
ZL1 Appearance package, Flow Master American Thunder Cat Back Exhaust w/ QUAD TIPS, K&N Typhoon CAI, Ported VMAX TB, OEM GM Brembo Brakes Package w/ Hawks Carbon Ceramic Pads, Night Owl Halo Kit (WIFI), Rear Oracle Blue LED Bowtie, Oracle Ghosted Painted Side LED Markers, Silver Sided Gills, OEM Satin Camaro Fuel Door, OEM Strut Tower Brace, Detroit Speed Engineering 1.5" Lowering Springs, Koni Orange STR.T Struts, Z28 rear LCA's, Black Magic rear 32" sway bar, 1LE front sway bar w/ DSE end links, Aluminum Blend Door, Evil Energy Catch Can.
SummitWhite11 is offline   Reply With Quote
Old 03-29-2024, 06:08 PM   #4
SummitWhite11
Drives: 2010 2LT/RS
2010 2LT/RS
Old 03-29-2024, 06:52 PM   #5
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
I thought it stiffened it up a bit when I first put it on. Didn't do much for the front end knockin' and bangin' over bumps these cars are famous for. But the wheels are still attached and it looks pretty good.
Moto-Mojo is offline   Reply With Quote
Old 03-30-2024, 10:37 AM   #6
SRB
Old 03-30-2024, 12:44 PM   #7
GasMasher
GasMasher's Avatar
Drives: 2014 Camaro 2SS/RS LS3
Unless you're driving hard on a track you won't notice any difference. They do look pretty with the hood popped if you're going for a nice cosmetic touch.
GasMasher is offline   Reply With Quote
Old 03-30-2024, 02:32 PM   #8
acutron42
acutron42's Avatar
Drives: 2013 Camaro 2SS AGM
This if funny lol! Mine is just utilitarian to get to the coil packs in a hurry @ the track or intake/valve covers. 4 bolts, 2 extension plugs, pop of the wires & it is all accessible.
2013 2SS GPI built & tuned 415, spec'd by Andrew Cammer. GPI ported intake/tb/heads, Tooley springs, CHE trunnions, Callies rotating assembly, Diamond pistons, GPI SS3 VVT, ATI 10% ud damper, Circle D 3800, Kooks ceramic coated lt's with green cats, Mishimoto rad & oil cooler, Derale trans cooler, Holley efi rails. DSS driveshaft, trutrac with 3.91's, G-Force renegades, Hendrix solid cradle bushings Bmr: poly diff bushings, Strange adjustable coilovers, sub frame connectors, ZL1 npps, controlled with a vac pump & mac boost control solenoid.
acutron42 is offline   Reply With Quote
Old 03-31-2024, 12:01 PM   #9
SOLUKY
Drives: Camaro 2SS
Is it okay to take off and paint? torque to what lbs. when I put back on?
SOLUKY is offline   Reply With Quote
Old 03-31-2024, 07:25 PM   #10
Rusty Shackleford
Drives: 2012 Camaro 2SS
I noticed a rigidity increase in the front end when i installed mine. No major difference in the way the car handles, it just seems to respond to input a little better. A little.
Rusty Shackleford is offline   Reply With Quote
Old 04-01-2024, 07:46 AM   #11
Arogg
A legend in his own mind
Arogg's Avatar
Drives: 2010 2SS/RS M6
Id like to add one to my engine bay, even its for minimal benefit but I have an early 2010 and im pretty sure almost any I add to a 2010 requires me dropping suspension to install and at that point, the minimal benefit isnt worth it.
2010 2SS/RS "The Mistress"
Color matched OEM GFX / VIS Carbon Fiber Hood (absolute trash quality and customer service ) / Heritage Grille / 5% Windows / 30% Windshield tint with 5% visor strip / Tinted Exterior Lights / Streetfighter LA Spoiler / Morimoto XB LED fogs / LED sidemarkers / Airaid CAI / Hurst Short Throw / TSP LT's / No cats / No resonator / Corsa Xtreme Catback / Trifecta Tune / Factory amp replaced / 2 JL Audio 12's / MRR 228 Wheels / BMR Springs / Koni Yellows / R1 Concepts Rotors & Pads
2006 Dodge Magnum RT "The daily"
Arogg is offline   Reply With Quote
Old 04-01-2024, 11:19 AM   #12
2010sgm
2010sgm's Avatar
Drives: 2010 Camaro 1LT
same feeling my friend!
David Vianu
2010 Synergy Green 1LT
2010sgm is offline   Reply With Quote
Old 04-01-2024, 12:15 PM   #13
Bee
Bee's Avatar
Drives: SS/RS - Rally Yellow
Yeah, those of us with 2010's and some of the 2011's have to drop the front suspension to drill holes in the towers. I had to take off the wheels, disconnect the front sway endlinks and then remove the front struts...otherwise, there was too much tension to get the retaining nuts loose.
As others have mentioned, it did stiffen up the steering a bit but I would categorize this one as mostly for looks with a small benefit in performance. In the end, I like how it eliminated the gap under the strut retainers.
Name:  2023-06-25 17.57.09.jpg
Name:  2023-07-02 11.18.31.jpg
Check out my build here.
SEPA5 South Eastern Pennsylvania 5th Gen Camaro Club
Bee is offline   Reply With Quote
Old 04-01-2024, 02:29 PM   #14
George-CZ
George-CZ's Avatar
Drives: 2010 2SS LS3 and 1978 STROKER 383
Attachment 1149118
Attachment 1149119
I did it in a combo together with polyurethane inserts of the entire rear axle mount and front radial rods.
And it was a night and day difference.
My life is a constant struggle with Camaro.
K&N CAI, Stainless Power longtubes, high flow cats, modified Ragazzon High Performance axle back, Soler Performance ported throttle body, Soler Performance throttle controller, RAM clutch adjuster, modified LS7 clutch kit, Tick Performance billet bearing support, Tick Performance remote bleeder, separate clutch reservoir, BMR trailing arms, BMR toe rods, Pedders Suspension cradle bushing inserts, Control Arm Bushings, Strut tower brace, oil catch can, Hurst T-handle shifter, 20mm wheel spacers, DBA brakes, QTP Cutouts, Dynosteve tune.
George-CZ is offline   Reply With Quote
