Old 04-03-2024, 09:27 AM   #1
96SS390
Drives: 2006 BOM GTO
Whipple under stock hood?
I found a used Whipple 2.9 and Im interested but from some of my light reading noted that some seem to suggest it wont fit with the vent. Any insight on what can be done and expected cost associated with doing it? Im not interested in aftermarket style hoods at the moment and will probably go LSA if this option isn’t feasible or super costly just to fit.
96SS390 is offline   Reply With Quote
Old 04-03-2024, 11:02 AM   #2
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
I removed the drip tray and notched the vent to clear my Whipple.
Sent from my Pixel 8 Pro using Tapatalk
Old 04-03-2024, 11:26 AM   #3
96SS390
I was hoping you would respond as your car was basically the only reference point I could find. When you say notched was this on the underside of the vents or did you have to cut parts of them off completely? Any pictures by chance?
Old 04-03-2024, 11:56 AM   #4
The_bald_eagle_machine
Anthony S
The_bald_eagle_machine's Avatar
Drives: 2011 chevrolet camaro 2ss/rs
Maybe you could just swap to a 2010-2013 stock hood? The cowl lines are a little bit different, but they don't have the hood vent that is causing the clearance issue. Just a thought. My understanding is that the hoods are interchangeable, but the cowl lines are different.
Follow me on instagram @Cthulu_the_trans_am
https://www.camaro5.com/forums/showthread.php?t=600181
2011 Camaro 2SSRS - Sold
No longer a 5th gen owner, but still an enthusiast. Ask me about my Front crash bars!
The_bald_eagle_machine is offline   Reply With Quote
Old 04-03-2024, 12:29 PM   #5
larry_g
larry_g's Avatar
I basically clearanced just enough. Not a great picture but you can see it if you zoom in...
Old 04-03-2024, 01:46 PM   #6
96SS390
Have you got caught out in the rain? I guess I'd be a little concerned with water ingress especially while parked. Though I guess I'd question how effectively the plastice tray really is at diverting water.
Old 04-03-2024, 01:47 PM   #7
96SS390
Have you got caught out in the rain? I guess I'd be a little concerned with water ingress especially while parked. Though I guess I'd question how effectively the plastic tray really is at diverting water.
Old 04-03-2024, 04:39 PM   #8
larry_g
larry_g's Avatar
I was daily driving it for a while and it definitely got wet.
Old 04-04-2024, 08:59 AM   #9
fz4k98
Drives: 2013 1ss
I have a 13 with a whipple and it does fit, but is so close it compresses the insulator. I wish i had a vent for the heat.
fz4k98 is offline   Reply With Quote
Old 04-04-2024, 03:48 PM   #10
Anthony S
This guy has a whipple with a custom vent mount. You lose the drip tray for sure.
