Old 04-05-2024, 10:19 AM   #1
skippy01
Drives: 2011 Camaro SS
rear gear swipe
I've got a 2011 SS LS3 i have a stage 4 cam headers Corsa exhaust and i was wondering if i could get better performance by changing the rear gears. Down the line i would like to do a pro charger and suggestions would be greatly appreciated.
skippy01 is offline   Reply With Quote
Old 04-05-2024, 10:47 AM   #2
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
Long duration cams respond well to steeper gears. Superchargers tend to need less gear but centrifugals come in later so you should be ok if you don't get too crazy on the power level.
