Old 04-06-2024, 10:54 AM   #1
Lou gill
Lou gill's Avatar
Drives: ‘13 ZL1 convertible
Complete fluid change
I am looking for some help please, I am bringing my 2013 ZL1 out of storage here in WI and I am changing all the fluids with top of the line Amsoil. Does anyone have a reference guide to the amount of fluids needed for:
Antifreeze
Rear Differential fluid
Brake fluid
Transmission fluid
Thank you in advance for the help!!
Lou gill is offline   Reply With Quote
Old 04-06-2024, 01:00 PM   #2
el ess A
Older Than Dirt
el ess A's Avatar
Drives: 2010 & 2013 Camaros
Got your owner's manual? It's in there.
Page 12-2.
2010 2SS TE, 1 of 822/2013 Camaro ZL1 vert, 1 of 54
http://www.camaro5.com/forums/image.php?type=sigpic&userid=26108&dateline=142898  4774
el ess A is offline   Reply With Quote
Old 04-06-2024, 10:58 PM   #3
AlisoBob
Drives: Camaro 2SS Gen 5
Amsoil is not "Top of the Line". It shows the exact same wear metals in the exact some concentrations as any other quality oil that cost's 50% less....
Is it good oil? Sure.
Does it live up to all the hype and cult following? No.
AlisoBob is offline   Reply With Quote
Old 04-07-2024, 01:16 AM   #4
ariZona28
Give speed a chance
ariZona28's Avatar
Here's 3 outta 4 from the Chilton manual. For brake fluid 2 (maybe 3) 12oz bottles should suffice if you're doing a flush. If just a quick bleed than just 1 should be ok. Your car does have the big Brembo calipers so you may want wait for someone to chime in that has flushed in DOT 4 for track use, they'd have an exact amount they used.
ariZona28 is offline   Reply With Quote
Old 04-07-2024, 01:58 AM   #5
chevy pilot
chevy pilot's Avatar
Drives: 2010 2SS/RS A6
Like Royal Purple.
Old 04-07-2024, 03:54 AM   #6
0stones0
It don’t come easy.
0stones0's Avatar
Drives: 2010 2SS RS M6
Think the OP is saying their using the high tier version of Amsoil. Like Signature series. But, thanks for lettings us know it’s over hyped and has a “cult following”.
0stones0 is offline   Reply With Quote
Old 04-07-2024, 01:11 PM   #7
daktah
daktah's Avatar
Drives: 2013 camaro 2ss 1le
does the tr6060 capacity spec include the cooler and lines (essentially "dry") or just a drain and fill? going to clear out the cooler too next change so curious how much i should add afterwards, especially since its basically impossible to get even a gallon into the case at a time from past experience.
2013 Camaro 2SS 1LE w/ RS [Rally Yellow]
Stock + Speed Engineering 1 7/8 LTHs w/ TSP HFCs, Roto-Fab CAI, Innovate DLG1/LC2 Dual WBo2, Smoked Wicker Bill, Self Tuned w/ HPTuners
daktah is offline   Reply With Quote
Old 04-07-2024, 01:30 PM   #8
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
That half liter difference between the SS and Zl1 TR6060s is the cooler lines and cooler. When I put diff coolers on my cars they took approximately 4.5 quarts to refill with the cooler in place.
Old 04-21-2024, 03:08 PM   #9
daktah
daktah's Avatar
so the capacity spec DOES include the lines and cooler? so if i were to drain the transmission, lines and cooler it would take the full 4.whatever quarts to fill everything back up and be at the correct level in the mt case?
Old 04-24-2024, 04:51 PM   #10
Lou gill
Lou gill's Avatar
Just checking if someone has changed the brake fluid, how much did it take to replace please
