![]() Drives: 2014 Black Non Ac Join Date: Mar 2019
Do any of you know what this is or what it says ?
Center console , under the bottom rubber , inside the holes ?Im not takiing mine apart , just curious of what is is . Anyone know ?
Banned
Drives: Camaro 1LE Join Date: May 2018
If I recall correctly, that's the yaw sensor. It's been a handful of years since I changed mine out, so I don't remember 100% if there was another sensor down there or not. 👍
![]() Drives: 2015 ZL1, 2015 Z28 Join Date: Dec 2018
The yaw sensor is a very good guess as they are frequently located under the console in various GM cars and even some foreign ones
![]() ![]() ![]() ![]() Drives: 2010 2SS/RS A6 Join Date: May 2019
If I recall correctly,bluetooth unit.
![]() Drives: 2013 ZL1 Convertible/2015 Z/28 Sold Join Date: Mar 2013
My educated guess from research:
13598483 MODULE,AIRBAG SENSOR & DIAGNOSTIC
#6 |
Since there are a lot of differing opinions here, the only way to be sure is to remove the console and get the ID numbers off the unit and run them through your dealership parts computer.
#7 |
Let us know when you confirm. I look at your pic and I see whats behind the holes on the part I posted so I am confident that is it. The left hole shows GM yellow and the exclamation point in a triangle. The right hole shows a C, the right side of the wrench and the bottom of the figure on top of the wrench.
