Old 04-14-2024, 08:38 PM   #1
SlowLS1
SlowLS1's Avatar
AGP owners, question about heat and harness
Do you guys think this routing of the main ecu harness, properly wrapped, is going to suffer from heat. Trying to finalize routing of the harness.
Thanks
Brian
SlowLS1 is offline   Reply With Quote
Old 04-15-2024, 07:24 AM   #2
SlowLS1
SlowLS1's Avatar
Please excuse the mess, it’s a work in progress…
The ecu is located in the cabin filter area and the path pictured is my preferred route for the harness to the engine. What’s in the picture is just the part of the harness that goes to passenger side of the engine on the bottom.
Any suggestions or opinions are appreciated.
Brian
Old 04-15-2024, 09:41 AM   #3
CamaroCracka
CamaroCracka's Avatar
Drives: 2010 Turbo LS3
I don't have AGP, but my single set up loves to melt loom in that area. This stuff holds up to the heat better than any other loom I have found, except maybe the silicone covered stuff, which is not split.
https://www.amazon.com/MGI-SpeedWare...st_sto_dp&th=1
Old 04-15-2024, 11:01 AM   #4
SlowLS1
SlowLS1's Avatar
Thanks for the feedback, I saved what you sent.
Something else I have considered to to fabricate a "gutter" for the harness to lay in. Crude sketch attached. I really don't want to do this, but it might be the better option. Thoughts?
Old 04-15-2024, 11:33 AM   #5
CamaroDreams76
Tri-County Camaro SWFL
CamaroDreams76's Avatar
Drives: 2013 IOM 2SS/RS/1LE
The harnesses just get tucked above the tran away from the turbos. I've had my AGP kit installed now for about 6 months and have put probably 2k miles on it. No issues with melting harnesses.
I can't tell exactly where the picture is. Looks like near the starter? Intercooler piping for the hot side runs right by there.
Old 04-15-2024, 11:47 AM   #6
SlowLS1
SlowLS1's Avatar
Looking at the last pic I posted, the stud on the bottom edge I marked in red is for the heat shield that runs underneath.
Starter on the right and the brake lines and fuel line on the left. Picture is a bit disorienting since everything is removed and different colors
Could you grab a pic of the same angle? I’d owe you one! If not, I understand.
Old 04-15-2024, 12:19 PM   #7
trashbasket
trashbasket's Avatar
Drives: 2010 Camaro
Hope that picture helps. I put DEI HeatShroud on it. Never had a problem.
2010 SS / 376 LSX / AGP Twin Turbo / 910whp 954wtq
trashbasket is offline   Reply With Quote
Old 04-15-2024, 02:25 PM   #8
SlowLS1
SlowLS1's Avatar
It does help! Thanks. I probably won't be running that heat shield that covers the heater core lines.
Old 04-15-2024, 04:00 PM   #9
trashbasket
Drives: 2010 Camaro
coincidentally that helped me find a header bolt that's missing lolol, so glad I went and snapped the pic
Old 04-15-2024, 06:07 PM   #10
CamaroDreams76
So that's basically where the cast agp collector goes that the BOV and turbo hang from. They both have heat shielding towards the trans. If you ran the wiring behind the oem heat shield i wouldn't worry about it. But no way you could run an unprotected loom.
Old 04-16-2024, 06:26 PM   #11
SlowLS1
SlowLS1's Avatar
I didn’t see it until you said something
Old 04-16-2024, 06:28 PM   #12
SlowLS1
SlowLS1's Avatar
Are you talking about the heat shield that protects the heater core lines? If so I am going to have to get creative. Didn’t plan to run that one anymore.
Old 04-17-2024, 07:53 AM   #13
CamaroCracka
I don't run a shield on my heater lines and the passenger side header even burnt the foam off the aluminum line. I do tuck a lot behind the heat shield that runs up from the trans tunnel and covers the inner fender.
Old 04-20-2024, 12:58 PM   #14
CamaroDreams76
I tried taking a picture of the area in reference but the headers, strut bar and big phone are hard to capture a clear image.
Yours is much lower but here's what mine looks like
