Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Site Related Announcements / Suggestions / Feedback / Questions
Old 04-19-2024, 06:24 AM   #1
Jarek
Jarek's Avatar
Drives: 2017 2SS Convertible
[OPEN] Request to enable BB Code table in the signature
Hi Admins,
Is there a possibility to enable creation of BB Code table like this (space inserted on purpose otherwise table header is not displayed):
[table ]
[tr]
[th][SIGPIC][/SIGPIC][/th]
[th]Text[/th]
[/tr]
[/table ]
in the signature section?
Goal is to be able to place picture and description next to each other to avoid going over 200pix limit (and having your picture cut as you can see in my current signature)
BR,
Jarek
Camaro SS 2017 Convertible, 2SS trim, V8 6.2L 455HP 618Nm, A8, Silver
Mods so far: K&N oil air filter, rear lamps EU conversion with sequential turn signal, exhaust mod to 4 tips (non-NPP), LED rear fog light (EU requirement), Diode Dynamics LED markers.
Mods planned: Morimoto LED lamps set (front)
Jarek is offline   Reply With Quote
Old 12-01-2024, 04:55 AM   #2
Jarek
Jarek's Avatar
@SSE 4 2SS
If you can have a look and tell if this is doable.
Old 01-21-2025, 01:52 PM   #3
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Turning on BB Code or adding this script definitely won't happen and the limits are there to keep signatures from getting too big. That's what a Journal is for that can be linked directly from your picture like mine is.
You also have too many lines of text taking up photo space. I removed this one... "Mods planned: Morimoto LED lamps set (front)" and now your picture shows at the bottom
Old 01-21-2025, 02:30 PM   #4
Jarek
Jarek's Avatar
Hi mlee
The problem was that the signature was getting too long not too big - my solution allows to utilize the empty space while still keeping the same length limit. That's why I would welcome solution to put picture side by side with text not below or above.
Old 01-21-2025, 02:35 PM   #5
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Originally Posted by Jarek View Post
Hi mlee
Yes, I understand... wish we could change it but this software is almost 20 years old and the signature layout just isn't going to change.
One thing we used to do was photoshop all the Text and mod lists into the picture and then just have the picture with no text.
Old 01-21-2025, 02:40 PM   #6
Jarek
Jarek's Avatar
Yes, I was thinking about adding text to the picture but it is not an elegant solution - rather a quick workaround
Old 01-21-2025, 02:56 PM   #7
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
It also helps when screen window is small and the text starts wrapping. My sig doesn't change.
Old 01-21-2025, 03:11 PM   #8
SSE 4 2SS
Boosted Moderator
SSE 4 2SS's Avatar
Drives: Bone Stock LS3
Thanks Mike,
You both quickly went over my head with the software comments… I forwarded the request a while back…
Old 01-21-2025, 03:25 PM   #9
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
Thanks Mike,
In the newer versions of Vbulletin there is an option to allow users to use their own BB Code, but you know that's not happening here LOL.
Old 01-22-2025, 08:37 AM   #10
Jarek
Jarek's Avatar
So in short this means that BB code table is not sth already available in the system just to be easily enabled, right?
Old 01-22-2025, 10:21 AM   #11
Mr_Draco
Mr_Draco's Avatar
Drives: 2SS/RS
What you are asking for wasn't added to vBulletin until version 4.2. We are on 3.8. As it stands now, no it is not something that can simply be enabled.
Old 01-22-2025, 10:37 AM   #12
Jarek
Jarek's Avatar
Understood, thank you. Now it is crystal clear.
Old 01-22-2025, 11:38 AM   #13
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
I couldn't remember how far back but knew it was there from forums I've created.
This one also took on major updates of it's own back in the day so a complete divergence from VB other than the DB.
