04-19-2024, 03:42 PM | #1 |
Drives: 2022 SS 1LE Join Date: Aug 2023
12V Switched Power in the Trunk
I had a hard time finding this information when I was looking for switched power in the trunk fuse box. I saw another post asking about it today, so I thought I would put the information here for future reference.
In the trunk fuse box there is a purple wire that allows you to tap into the accesory circuit. This is only powered when the ignition is in the ACC or ON position. In the pic below, refer to the purple wire with the red arrow pointing at it. Not the one with the probe. Hope this is helpful. |
04-20-2024, 09:42 PM | #2 |
Petro-sexual
KUDOS AND THANKS!!!
'20 ZL1 Black "Fury" A10, PDR, Exposed CF Extractor Magnuson Magnum DI TVS2650R // RFBG // Soler 103 // TooHighPSI Port Injection // THPSI Billet Lid // FF // Katech Drop-In // PLM Heat Exchanger // ZLE Cradle bushings // BMR Chassis-Suspension Stuff // aFe Bars // Diode Dynamics LEDs // ACS Composites Guards // CF Dash // Aeroforce // tint // other stuffs |
Yesterday, 12:10 PM | #3 |
Geoff
Drives: 2020 ZL1 Green Join Date: May 2013
Alternative
I was adding some Wide bands and wanted switched power. This is the ticket!
I was wondering if there are any switched fuses so I could use an "add a circuit" instead of a tap. Lots of angst and investigation later, there are some! F33-WCM "wireless charger" F19-frt vent seat F17-Spare F12-htd str whl I used the spare, F17, circled in yellow. the other add a circuit is for an intercom, it is in F23, BCM 1, constant 12v Thx to ChibbMD for getting this started!
