![]() Drives: 2011 Camaro ss Join Date: Jan 2020
Who to build an engine?
I need to get my LS 3 rebuilt. What are some recommended places to do so? Closer to Annapolis Maryland the better but will drive for a good build and a good deal.
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 2SS/RS, '22 Silverado Z71 Join Date: Sep 2010
Are you doing upgrades or just getting your stock motor redone because of a failure of some kind?
It did have a failure, started it up and just sounded like it was down a cylinder. Gave it a little.throttle and blue smoke out of the drivers exhaust. Did a compression check on driver side and cylinder 1 was down. So now I need a rebuild...
The motor is supposed to be a 415 forged stroker, I have no documentation on that though. And when I had it returned it only.made 570 rwhp at 8psi which seemed to be more on par with a cam only motor. So now I don't know if the motor is stock with a cam...forged....or stroked. If its stroked then im assuming there was already some damage that happened. So as far as a stock rebuild or upgrades, it really depends on what is already inside of the motor. |
Since you are in MD, I think Maryland Speed is a shop I've heard from guys over there. I think they are a sponsor on here or at least used to be.
If you can't find anyone over there and don't mind the drive. We have Horsepower Addicts and Race Proven Motorsports.... both are up in Wilmington, DE. I've used HA twice for both of my tunes. The guy I used for my rebuild left and went down to the beach somewhere. He did it as a side gig. I ended up just doing an LS3 conversion with upgraded oil pump and springs.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
To add to those shops, if you don't mind coming to PA, both Injection-Connection and Complete Street Performance are great shops too.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
#6 | |
Boosted Moderator
Drives: Bone Stock LS3 Join Date: Sep 2009
OP, being in MD, I recommend you reach out to Jannetty Racing Ent. They are located in Waterbury Conn... Great guy, and if he cant help you he can and will make a great recommendation... 203-753-7223 tedj@jannettyracing.com Katech is another great (engine builder) shop, though they are in Clinton Twp Michigan.... 586-791-4120 store@katechengines.com
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. “If everything seems under control, you're just not going fast enough.” Mario Andretti If you can turn, you ain't going fast enough... |
